[Geoserver-devel] Status of Boundless maven repositories?
Hi List,
What is the status of Boundless maven repositories?
I thought from a couple of emails I have seen yesterday that now they are working, however I see Travis is still failing on retrieving the updated jars.
The current geoserver build failures are due to updated gt-main classes not used.
There is a pull request for that:
https://github.com/geoserver/geoserver/pull/1277
However, the travis build for that pull request is failing since it doesn’t get the latest GT classes from the latest deployment. I guess It is still using old jars
(Everything works fine locally)
Please, let me know.
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
There was a status update yesterday’s meeting.
Since that time:
  • andrea merged a commit from Frank experimenting with direct use of artifactoryonline URL. How did that go Frank?
  • repo.boundlessgeo.com changed to a proxy (rather than a redirect)
Watching the builds shows a marked improvement on ares (not seeing any 302 Found responses being saved to pom.xml or jar files).
On 21 October 2015 at 03:24, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi List,
Daniele
Geoserver-devel mailing list
Jody Garnett
Little update on this one while fixing uDig build. This may interest you because I started a build form scratch with an empty local repository and same settings for boundless repository:
boundless Boundless Maven Repository [https://repo.boundlessgeo.com/main/](https://repo.boundlessgeo.com/main/) true true
The main problem is that releases/enabled is set to true. If so all release jars and pom files are corrupt, e.g. https://repo.boundlessgeo.com/main/org/slf4j/log4j-over-slf4j/1.6.4/log4j-over-slf4j-1.6.4.pom
looks like this:
  "errors" : [ {
    "status" : 404,
    "message" : "Could not find resource"
It looks like metadata are not up-to-date because "folder" [https://repo.boundlessgeo.com/main/org/slf4j/log4j-over-slf4j/1.6.4/](https://repo.boundlessgeo.com/main/org/slf4j/log4j-over-slf4j/1.6.4/) is empty...
I'm wondering that all gs-builds are running smooth but I assume the builds using a global repository where the releases are still available. If jenkins/hudson builds using local to workspace repositories I would suggest to clean it before build starts.
HTH
Frank
2015-10-21 17:28 GMT+02:00 Jody Garnett <jody.garnett@anonymised.com>:
Since that time:
Jody Garnett
Hi List,
Daniele
FWIW: I cannot download older geoscript-groovy releases from boundless repostories anymore. I raised a ticked : https://github.com/geoscript/geoscript-groovy/issues/25
  • Frank
2015-11-24 23:35 GMT+01:00 Frank Gasdorf <fgdrf@anonymised.com>:
looks like this:
  "errors" : [ {
    "status" : 404,
HTH
Frank
2015-10-21 17:28 GMT+02:00 Jody Garnett <jody.garnett@anonymised.com…403…>:
Since that time:
Jody Garnett
Hi List,
Daniele
