Hi List,
An minor observation, hopefully not noise - I use the “Excel output format” extension and one of the files that it comes with is stax-api-1.0.1.jar (that’s the version in the 2.5 beta anyway).
However GeoServer distribution already has one of these files in the same location. A comparison of their hashes show’s they’re identical.
So my question - does this file need to be in the Excel extension?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Nope, if its included in the core by default then no need to include it in the extension.
On Tue, Jan 21, 2014 at 4:36 AM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi List,
Jonathan
CenturyLink Cloud: The Leader in Enterprise Cloud Services.
Learn Why More Businesses Are Choosing CenturyLink Cloud For
Critical Workloads, Development Environments & Everything In Between.
Get a Quote or Start a Free Trial Today.
http://pubads.g.doubleclick.net/gampad/clk?id=119420431&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Geoserver-devel@anonymised.comt
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
