Chris Holmes wrote:
No problem. I also might be able to hit it this afternoon - if I do I'll close the task. Anything I can do to help you guys out?
Sure Chris - we are punting the UI through its paces - and we are missing a couple of pages.
Two that you asked for:
welcome.wfs - human readable version of getCaps document
welcome.wms - human readable version of getCaps document
And one that I want:
admin.lock - feature lock control (only care about a button that lets you clear all locks)
I use the same string (admin.lock) for several things:
- name of forward
- name of tile
- key to look up information in ApplicationResources.propertiers
Example 1: A new page - Feature Lock Administration
The first place to start is with tiles-defs.xml (which I have started commenting)
Add an entry for the 'page' you want:
<definition name="admin.lock" extends=".mainLayout">
<put name="key" value="admin.lock"/>
<put name="body" value="/WEB-INF/pages/AdminLock.jsp"/>
<put name="layer" value="administration"/>
<put name="locationForwards" value="welcome:admin"/>
<put name="actionForwards" value="clearLocks"/> </definition>
For this example I will use admin.lock because it covers most things:
key - same as page name (because I can't figure out how to get page name)
body - name of JSP that implements your page
layer - controls style used to display your page (see style.css)
locationForwards - list of forwards for the location bar
actionForwards - list of forwards for context sensitive actions
Up next is the ApplicationResources.properties file:
admin.lock.label=Lock
admin.lock.title=Feature Lock Administration
admin.lock.short=Administration of FeatureLocks for GeoServer
admin.lock.words=(Administration) (FeatureLock) (Lock)
Where this contains all the internationalization stuff:
label - is displayed in the location bar as the text for the link
title - is displayed on the page (and in the window)
short - short description used for tooltip help text, and page abstract
words - keywords for page
From here you can go off to struts-config.xml:
Step 1: Form Bean
- If you are doing input you will need a form-bean entry:
<form-bean
name="loginForm"
type="org.vfny.geoserver.form.LoginForm"/>
Step 2: Forward
- uses the same ID as in the tiles-defs.xml and ApplicationResources.properties file
- used to separate out application from the url structure
- the path will be used to look up the Action
<forward
name="admin.lock"
path="/AdminLock.do"/>
Step 3: Action
- this is the only thing that does work
- path matches to the forward
- parameter matches to the entry in tiles-defs.xml
- name (like name="loginForm" ) matches a form-bean if you use one
<action
path ="/AdminLock"
type="org.apache.struts.actions.ForwardAction"
parameter="admin.lock"/>
Example Two - Action with no Page - Clear Locks
- we also needed a "clearLocks" action (that does not have a page)
- no parameter required - this action does not have a page
- name is the name of a form-bean - in this case an empty blankBean is used
struts-config.xml
<forward
name="admin.lock.clear"
path="/ClearLocks.do"/>
<action path="/ClearLocks"
type="org.vfny.geoserver.action.admin.ClearLocks"
name="blankBean"/>
ApplicationResources.properties:
admin.lock.label=Clear All Locks
admin.lock.short=Clear all outstanding FeatureLocks
From MAILER-DAEMON Tue Feb 24 22:53:45 2004
To: geoserver-devel@anonymised.com
X-Spam-Score: 2.1 (++)
X-Spam-Report: Spam Filtering performed by sourceforge.net.
See Apache SpamAssassin: Welcome for more details.
Report problems to SourceForge.net Legacy Resources download | SourceForge.net
0.3 NO_REAL_NAME From: does not include a real name
1.6 LARGE_HEX BODY: Contains a large block of hexadecimal code
0.3 UPPERCASE_25_50 message body is 25-50% uppercase
Subject: [Geoserver-devel] failure notice
Sender: geoserver-devel-admin@lists.sourceforge.net
Errors-To: geoserver-devel-admin@lists.sourceforge.net
X-BeenThere: geoserver-devel@lists.sourceforge.net
X-Mailman-Version: 2.0.9-sf.net
Precedence: bulk
List-Unsubscribe: <https://lists.sourceforge.net/lists/listinfo/geoserver-devel>,
<mailto:geoserver-devel-request@lists.sourceforge.net?subject=unsubscribe>
List-Id: Geoserver Developers' List <geoserver-devel.lists.sourceforge.net>
List-Post: <mailto:geoserver-devel@lists.sourceforge.net>
List-Help: <mailto:geoserver-devel-request@lists.sourceforge.net?subject=help>
List-Subscribe: <https://lists.sourceforge.net/lists/listinfo/geoserver-devel>,
<mailto:geoserver-devel-request@lists.sourceforge.net?subject=subscribe>
List-Archive: <http://sourceforge.net/mailarchive/forum.php?forum=geoserver-devel>
Date: Tue Feb 24 22:54:07 2004
X-Original-Date: 25 Feb 2004 06:52:34 -0000
Content-Type: text/plain; charset="utf-8"
Content-Transfer-Encoding: 8bit
Hi. This is the qmail-send program at siamguru.com.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
<kde-i18n@anonymised.com>:
211.39.143.146 does not like recipient.
Remote host said: 550 Unknown local part kde-i18n in <kde-i18n@anonymised.com>
Giving up on 211.39.143.146.
--- Below this line is a copy of the message.
Return-Path: <geoserver-devel@anonymised.com>
Received: (qmail 55058 invoked from network); 25 Feb 2004 06:52:28 -0000
Received: from unknown (HELO lists.sf.net) (203.149.56.66)
by web1.siamguru.com with SMTP; 25 Feb 2004 06:52:28 -0000
To: kde-i18n@anonymised.com
Subject: Readme
Date: Wed, 25 Feb 2004 13:52:26 +0700
MIME-Version: 1.0
Content-Type: multipart/mixed;
boundary="----=_NextPart_000_0007_A7BA8FDF.059DBA48"
X-Priority: 3
X-MSMail-Priority: Normal
This is a multi-part message in MIME format.
------=_NextPart_000_0007_A7BA8FDF.059DBA48
charset="Windows-1252"
Content-Transfer-Encoding: 7bit
Details are in the attached document. You need Microsoft Office to open it.
Content-Type: application/octet-stream;
name="image.zip"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="image.zip"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------=_NextPart_000_0007_A7BA8FDF.059DBA48--
