today I was trying to edit a style on master, and while clikcing “apply” was working just fine,
hitting submit resulted in:
org.apache.wicket.WicketRuntimeException: Null object returned for expression: legend.width for setting value: 0 on: StyleInfoImpl[dem] at org.apache.wicket.core.util.lang.PropertyResolver.setValue(PropertyResolver.java:148) at org.apache.wicket.model.AbstractPropertyModel.setObject(AbstractPropertyModel.java:131) at org.apache.wicket.Component.setDefaultModelObject(Component.java:3082) at org.apache.wicket.markup.html.form.FormComponent.setModelObject(FormComponent.java:1579) at org.apache.wicket.markup.html.form.FormComponent.updateModel(FormComponent.java:1097) at org.apache.wicket.markup.html.form.Form$FormModelUpdateVisitor.component(Form.java:229) at org.apache.wicket.markup.html.form.Form$FormModelUpdateVisitor.component(Form.java:199) at org.apache.wicket.util.visit.Visits.visitPostOrderHelper(Visits.java:274) at org.apache.wicket.util.visit.Visits.visitPostOrderHelper(Visits.java:262) at org.apache.wicket.util.visit.Visits.visitPostOrderHelper(Visits.java:262) at org.apache.wicket.util.visit.Visits.visitPostOrderHelper(Visits.java:262) at org.apache.wicket.util.visit.Visits.visitPostOrderHelper(Visits.java:262) at org.apache.wicket.util.visit.Visits.visitPostOrderHelper(Visits.java:262) at org.apache.wicket.util.visit.Visits.visitPostOrderHelper(Visits.java:262) at org.apache.wicket.util.visit.Visits.visitPostOrder(Visits.java:245) at org.apache.wicket.markup.html.form.FormComponent.visitComponentsPostOrder(FormComponent.java:423) at org.apache.wicket.markup.html.form.Form.internalUpdateFormComponentModels(Form.java:1864)
Am I the only one seeing this? This is a fresh build, no extra plugins installed (so unrelated to the other
ticket already present in Jira, which has likely to do with plugins interactions)
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
