[Geoserver-devel] SVN Commit Access
Ok so here is the deal with svn:
Project despots on codehaus are note able to hack the svnpasswd file anymore so everyone who wants commit access needs to set up a proper codehaus account.
To do this you must file a jira request against the Codehaus Chores project (http://jira.codehaus.org/browse/HAUS) on the "Account Creation" component.
If I am not mistaken requests for account creation need to be authorized by a project despot (ie me). So I am going to put in a batch request for the following users.
cholmes
dblasby
bowens
jgarnett
groldan
louiecw
simboss
afabiani
I know I have missed people, I dont have the old svnpasswd file to go off of. So if I have missed you please just email me and let me know what you want your userid to be.
-Justin
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Yes, I am waiting for accounts to be setup before people can commit, I have put in the request so it should be happening soon.
So if you commited anything after the 7th, you have lost that work. Looking at the commit logs I noticed the following files on the wcs-branch have been modified since May 7th.
May 7th:
branches/wcs-branch/trunk/geoserver/build.xml
branches/wcs-branch/trunk/geoserver/cite/confUserBasic/WEB-INF/catalog.xml
branches/wcs-branch/trunk/geoserver/documents/geoserver.nsi
May 14th:
branches/wcs-branch/trunk/geoserver/src/org/vfny/geoserver/wms/responses/GetMapResponse.java
You might still have your work from the 7th, I am not sure. But definitley not from May 14th.
So its *important* to note that your local copy is now out of sync with whats in the repository, so if you try to commit as is you risk corrupting your local checkout.
So once your account is setup and you have commit access, here is what you must do:
1. Back up your local copy.
2. Checkout a new copy of the wcs-branch somewhere else
3. Manually diff the files listed above that were changed, and apply them to your new checkout.
4. Commit your new checkout as normal.
The changes look pretty simple so you should be able to do a simple diff + patch command (if you are a unix user).
If you have any more questions or anything is unclear please let me know. Hopefully accounts will be set up soon and you will be able to commit.
-Justin
Alessio Fabiani wrote:
Hi Justin,
I try to commit GeoServer updates but my SVN user password doesn't work
anymore. Can you help me with this issue?
        Alessio.
codehaus account.
  component.
cholmes
dblasby
bowens
jgarnett
groldan
louiecw
simboss
afabiani
-Justin
Justin Deoliveira
All the advantages of Linux Managed Hosting--Without the Cost and Risk!
Fully trained technicians. The highest number of Red Hat certifications in
the hosting industry. Fanatical Support. Click to learn more
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=107521&bid=248729&dat=121642
Geoserver-devel mailing list
Justin Deoliveira
