[Geoserver-devel] Switching to Spotless for Java formatting, status and request for help
as discussed in the PSC meetings and follow up mails, I’ve been playing with
Spotless to replace the dying COVEO formatting plugin.
Here is a test PR:
https://github.com/geotools/geotools/pull/3761
Highlights:
  • Uses Spotless for Java formatting, and uses the latest google-java-format plugin compatible with Java 8 (with improved formatting for streams and annotations)
  • Uses up-to-date checking to avoid re-formatting files for nothing
  • The up-to-date file index is kept in a hidden file in each module, “.spotless-index”. On linux that’s invisible by default. The files are in gitignore so they won’t be committed.
    Using spotless, we’ll be eventually able to also format with other formatters in the future, like the Eclipse one for XML/HTML for example.
Can people on different platforms try that out and tell me how that works for them? Try running:
mvn spotless:apply -nsu -Dall
Expect a few messages from spotless on the first run, while it’s creating the index files, and then it should be real fast from the second run onwards.
Github actions won’t get a speedup unless we find a way to cache the index files… not sure that we want to do that honestly (might be
complicated to setup and maintain, on a per branch basis…)
I tried it on linux. This command works OK, unsurprisingly.
Looks like there were a couple of spots you missed in dealing with the old
coveo based formatter. See PR against your branch.
For novelty, I also tried it on a Windows 11 VM with netbeans. It was a bit
messy to do within the IDE, but I think it ran OK. It worked fine on the
command line (once I found maven).
Test configuration:
Apache Maven 3.6.3 (cecedd343002696d0abb50b32b541b8a6ba2883f)
Maven home: c:\Program Files\NetBeans-12.6\netbeans\java\maven\bin\..
Java version: 1.8.0_312, vendor: Temurin, runtime: C:\Program Files\Eclipse
Adoptium\jdk-8.0.312.7-hotspot\jre
Default locale: en_US, platform encoding: Cp1252
OS name: "windows 10", version: "10.0", arch: "amd64", family: "windows"
openjdk version "1.8.0_312"
OpenJDK Runtime Environment (Temurin)(build 1.8.0_312-b07)
OpenJDK 64-Bit Server VM (Temurin)(build 25.312-b07, mixed mode)
Thanks, issues noted, I’ll try to address them in the upcoming weekends.
Great, thanks for testing!
Do we have anyone on OSX?
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
I tried it on Mac OSX. No issues and no code changes.
mvn -v
Apache Maven 3.8.4 (9b656c72d54e5bacbed989b64718c159fe39b537)
Maven home: /usr/local/Cellar/maven/3.8.4/libexec
Java version: 1.8.0_171, vendor: Oracle Corporation, runtime: /Library/Java/JavaVirtualMachines/jdk1.8.0_171.jdk/Contents/Home/jre
Default locale: nb_NO, platform encoding: UTF-8
OS name: “mac os x”, version: “10.16”, arch: “x86_64”, family: “mac”
Best regards,
Roar Brænden
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Thanks! (no code changes expected indeed, I did run a reformat before pushing the branch).
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
