[Geoserver-devel] Terminology question: SLD "variable substitution" or SLD "parameter substitution"?
The GeoServer doc uses two different terms to refer to SLD variable substitution. I would like to make this consistent in the User Guide, so I’m asking for comments on which one should be the standard wording.
The WMS GetMap vendor parameter page uses “variable substitution”:
http://docs.geoserver.org/stable/en/user/services/wms/vendor.html#env
The SLD section uses “parameter substitution”:
http://docs.geoserver.org/stable/en/user/styling/sld-extensions/substitution.html
I lean towards using “variable substitution”, for the following reasons:
  • the use of the “env” seems like a reference to UNIX-style environment variables
  • the word “parameter” is easy to confuse with the concept of WMS request parameters, since both are used in the same context
Thoughts?
Martin Davis
OpenGeo - http://opengeo.org
Hey Martin,
Thanks for making this consistent. I don’t have a strong opinion on this one but I think i have heard it referred to more often as “parameter substitution”. But from a naming standpoint i agree that I think i like variable substitution.
Maybe we can split the difference and call it “www substitution”. (inside joke)
-Justin
On Sun, Apr 15, 2012 at 12:36 AM, Martin Davis <mdavis@anonymised.com…> wrote:
Thoughts?
Martin Davis
For Developers, A Lot Can Happen In A Second.
Boundary is the first to Know…and Tell You.
Monitor Your Applications in Ultra-Fine Resolution. Try it FREE!
http://p.sf.net/sfu/Boundary-d2dvs2
Geoserver-devel mailing list
Justin Deoliveira
On Sun, Apr 15, 2012 at 8:53 AM, Justin Deoliveira <jdeolive@anonymised.com.1501…> wrote:
Hey Martin,
Justin, one day you should add “www” as your middle name :-p
I believe I’ve also heard it more often called “parameter substitution”, then again,
MapServer calls the equivalent concept “variable sustitution”:
http://mapserver.org/mapfile/variable_sub.html
So I’d go for variable, consistent among projects is even better than consistency
among the GeoServer own documentation :-p
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Excellent, I’ll make the change.
And good point about consistency across projects, Andrea - I agree 100% that this should be followed, whereever it makes sense.
M
On Sun, Apr 15, 2012 at 8:39 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sun, Apr 15, 2012 at 8:53 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hey Martin,
Ing. Andrea Aime
Tech lead
Martin Davis
