[Geoserver-devel] Test Failures in Web modules
I’m getting loads of Unit test failures when I build from
https://github.com/geoserver/geoserver/commit/4a4fcee9b960d3f63f320d4c28b342d06d750743
The last commit before my PR for GSIP-113.
Going back to the commit before the CodeMirror updates builds fine
https://github.com/geoserver/geoserver/commit/b7fa881f4bbc69025cf64b9aa741c136890b96c8
MAVEN_OPTS=“-Xmx1024m -XX:MaxPermSize=256m -XX:PermSize=128m” mvn test -Pjdbcconfig -Prelease -T4 -B
I’ve tried two machines (Ubuntu 12.04, Ubuntu Gnome 14.04), both Oracle and OpenJDK,and I’ve wiped my maven repo and downloaded everything fresh, upped the Perm space, and I still get the same failures and errors.
Does anyone have any idea what’s going on? It’s making it hard to check that my fix for the failure I introduced in GSIP-113 is working.
These are the tests failing for me in the WMS UI and Demoes modules. The other web UI modules have similar errors.
Results :
Failed tests: testStyleNewPage(org.geoserver.wms.web.admin.AdminPrivilegesTest): expected: but was:
Tests in error:
testLoad(org.geoserver.wms.web.data.StyleEditPageTest)
testChangeName(org.geoserver.wms.web.data.StyleEditPageTest)
testNewStyleNoSLD(org.geoserver.wms.web.data.StyleNewPageTest): path: ‘form’ does not exist for page: BrowserInfoPage
testLoad(org.geoserver.wms.web.data.StyleNewPageTest): path: ‘form:SLD:editorContainer:editor’ does not exist for page: StyleNewPage
testNewStyle(org.geoserver.wms.web.data.StyleNewPageTest): Unable to set value. Couldn’t find component with name: SLD:editorContainer:editor
Tests run: 22, Failures: 1, Errors: 5, Skipped: 0
Results :
Tests in error:
testProxyBaseUrl(org.geoserver.web.demo.DemoRequestsPageTest)
testUrlLinkSelected(org.geoserver.web.demo.DemoRequestsPageTest)
testStructure(org.geoserver.web.demo.DemoRequestsPageTest): path: ‘demoRequestsForm:body:editorContainer:editor’ does not exist for page: DemoRequestsPage
Tests run: 19, Failures: 0, Errors: 3, Skipped: 1
Kevin Smith
Junior Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
On Tue, Jun 3, 2014 at 8:48 PM, Kevin Smith <ksmith@anonymised.com> wrote:
I'm getting loads of Unit test failures when I build from
[GEOS-5143] Detect codemirror unsupported editors and fall back to te… · geoserver/geoserver@4a4fcee · GitHub
Doh, I could not get my build past the wms module so I did not get there.
From the failures I think I see what's going on, the browser detection code
is changing test
expectations. I can try to fix it tomorrow, but if you have a proper fix
for the wms failures
and want to get the build back in shape, please go and revert that merge.
Meet us at GEO Business 2014! in London! Visit Visit GeoSolutions at GEO Business 2014 in London! - GeoSolutions
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
