thanks for the patch.
We are closing the feature freeze for the 2.7.x series and developers are rather busy,
could you open a ticket at http://jira.codehaus.org/browse/GEOS and attach the patch
there, this will make sure it does not get forgotten.
We’ll apply the patch once someone develops a unit test (I hope to be able to help,
develop the test and merge the patch, but I cannot promise to do it quickly)
On Wed, Jan 7, 2015 at 12:57 PM, <as1613867@anonymised.com> wrote:
Actually, the x position of the background graphic is based on the last line of the multi line label.
This works well when the AnchorPointX is 0, but when the AnchorPointX is 1 the graphic appears shifted from the label (see left side of image attached).
In attach is a very simple patch to correct the issue on file modules/library/render/src/main/java/org/geotools/renderer/label/LabelPainter.java
Sorry, I’m not a developer and can’t figure out how to develop a unit test case.
I tested manually changing the AnchorPointX to 0, 0.5 and 1.0 and seems to work fine in all situations.
Best regards,
Paulo
Dive into the World of Parallel Programming! The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
