[Geoserver-devel] Thinking about community modules packaging
I’ve got reports that the COG community module packaged zip bundles are not working any
longer. Looking into it, it seems there are conflicting versions of dependencies that are causing the trouble.
As you probably know, the packaging is currently done this way:
  • A “release” module depends on all the modules that want to be packages
  • The release module dumps all these module dependencies into a single directory
  • Each module packaging descriptor picks from that pile of jars using globs
    Now, we already had some issues with incompatible dependency versions, but we more or less managed. Now there is a group of 3 different community modules that depend, in turn, to AWS and Azure cloud libraries, which in turn depend on Netty. Unfortunately, two different and incompatible versions of it.
Ideally, we could just upgrade the Azure blob storage library in GWC, but that amounts to a rewrite of the module.
Rather than doing that, I’d suggest to untangle community module packaging in the simplest possible way:
  • Have each module collect its own dependencies in target/dependencies when a specific profile is used (e.g., -Passembly?)
  • Have the assembly descriptor point at its own module
  • Get rid of the “release” module
    Ideally we could do that for extensions as well, but I’d try that with community modules first.
Thoughts?
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
I would like to see each module contains its own assembly, it would make things more normal.
Initially we made the release module to force assembly to occur at the end, and to avoid taking the time to build download artifacts during day to day development.
We could keep the release profile and only build zip download bundles when it is used.
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Hi Jody.
yes each module would have the assembly configuration local, besides its pom.xml.
I’ve made a small experiment, on the COG module alone, this should work:
cog-plugin zip false target/dependency annotations-2.*.jar auth-2.*.jar aws-*-2.*.jar azure-storage*.jar checksums-*2*.jar client-runtime*.jar crt-core-*-2*.jar endpoints-spi-2*.jar gs-cog*.jar http-auth-*2*.jar http-client-spi-2*.jar http*-osgi*.jar imageio-ext-*rangereader*.jar identity-spi*.jar jackson-datatype*.jar jackson-module*.jar kotlin-stdlib*.jar metrics-spi-2.*.jar *netty*.jar okhttp*.jar okio*.jar profiles-2.*.jar protocol-core-2.*.jar reactive-streams*.jar regions-2.*.jar rxjava*.jar s3-2.*.jar sdk-core-2.*.jar utils-2.*.jar target gs-cog*.jar
To work, it still requires dependencies:dependency-copy to run, which we can either have running
subject to a flag, or move it as part of the explicit build instructions.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
If it’s helpful, the maven assembly plugin has a concept of ‘dependencySets’, which could replace some of the fileSets and allow you to avoid running dependencies:dependency-copy.
Emilio
Sent: Wednesday, May 29, 2024 10:40 AM
To: Jody Garnett jody.garnett@anonymised.com
Cc: GeoServer geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Thinking about community modules packaging
Hi Jody.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
On Wed, May 29, 2024 at 4:35 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
On Wed, May 29, 2024 at 1:15 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Thoughts?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Geoserver-devel mailing list
Geoserver-devel@anonymised.comurceforge.net
Hi Emilio,
I’m aware of it, but there are issues… one one side, we want to package in the zip file only the jars that are not already covered by core.
The other bit is, even if there was a way to achieve the above, all 74 community module packaging files would have to be individually rewritten.
What I’m proposing is simple, mechanical, and can be at least partially automated, which means, it fits a small budget.
If we can party up with several people and attempt a technically better approach, so that my isolated effort is more or less the same,
I’m all for it!
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Sounds good, dependency sets do provide include/exclude filtering1 (or if the pom already has things correctly scoped as provided vs compile then you can easily filter out provided), but I’m all for easy wins!
Emilio
Emilio Lahr-Vivaz
General Atomics, CCRi
Sent: Wednesday, May 29, 2024 11:15 AM
To: Lahr-Vivaz, Emilio <Emilio.Lahr-Vivaz@…8176…>
Cc: Jody Garnett <jody.garnett@…403…>; GeoServer geoserver-devel@lists.sourceforge.net
Hi Emilio,
I’m all for it!
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
On Wed, May 29, 2024 at 5:06 PM Lahr-Vivaz, Emilio <Emilio.Lahr-Vivaz@…8176…> wrote:
Emilio
To: Jody Garnett <jody.garnett@…403…>
Cc: GeoServer <geoserver-devel@lists.sourceforge.net>
Hi Jody.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
On Wed, May 29, 2024 at 1:15 AM Andrea Aime <andrea.aime@…6887…> wrote:
Thoughts?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
I’m afraid this would solve the packaging issue but not the problem of deploying both the COG and the Azure blobstore extensions, as you’d end up with duplicate netty dependencies with incompatible versions.
In GeoServer Cloud I had to deal with this specific issue, using the “dependencyConvergence” maven enforcer plugin rule [1], and ensuring a single version of each duplicate dependency is in place. With the additional overhead of ensuring the plugins whose dependencies are overridden still work.
For the specific case of the netty version, I’m pegging it to 4.1.41.Final. Both COG and Azure blobstore work with that one.
The libs are in the pom’s “dependencyConvergence” maven profile [3].
So probably we could do something similar in geoserver to ensure a single version of each dependency is ever present.
Though that’d probably open its own can of worms. Perhaps just making sure both COG and Azure blobstore carry over netty 4.1.41.Final would suffice for the time being, without a rewrite of the Azure blobstore?
[1] https://github.com/geoserver/geoserver-cloud/blob/main/src/pom.xml#L904
[2] https://github.com/geoserver/geoserver-cloud/blob/main/src/pom.xml#L30-L32
[3] https://github.com/geoserver/geoserver-cloud/blob/main/src/pom.xml#L1070-L1124
camptocamp
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
Gabriel Roldán
Geospatial Developer
Hi Gabriel,
my plan would be to split the COG module into sub-parts, because when one needs to deploy on AWS, the azure libraries are not needed,
and vice versa. So make a packaging looking like:
  • cog-core (http support)
  • cog-aws
  • cog-azure
  • cog-google
    That should hopefully solve the issue, because cog-azure uses the azure-storage-blob v11, just like the blobstore.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
camptocamp
Gabriel Roldán
Hey guys,
I don’t want to put any additional work on anyone, but if anyone is feeling inspired, netty 4.1.41.Final has several high-severity CVEs out against it1 (current latest is 4.1.110.Final).
Emilio Lahr-Vivaz
Sent: Thursday, May 30, 2024 10:45 AM
To: Gabriel Roldan gabriel.roldan@anonymised.com
Hi Gabriel,
  • cog-aws
  • cog-azure
  • cog-google
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
On Thu, May 30, 2024 at 4:38 PM Gabriel Roldan <gabriel.roldan@anonymised.com…> wrote:
In GeoServer Cloud I had to deal with this specific issue, using the “dependencyConvergence” maven enforcer plugin rule 1, and ensuring a single version of each duplicate dependency is in place. With the additional overhead of ensuring the plugins whose dependencies are overridden still work.
1 https://github.com/geoserver/geoserver-cloud/blob/main/src/pom.xml#L904
camptocamp
Gabriel Roldán
On Wed, May 29, 2024 at 12:35 PM Lahr-Vivaz, Emilio <Emilio.Lahr-Vivaz@anonymised.com> wrote:
Emilio
Emilio Lahr-Vivaz
To: Lahr-Vivaz, Emilio <Emilio.Lahr-Vivaz@anonymised.com>
Cc: Jody Garnett <jody.garnett@anonymised.com>; GeoServer <geoserver-devel@lists.sourceforge.net>
Hi Emilio,
I’m all for it!
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
On Wed, May 29, 2024 at 5:06 PM Lahr-Vivaz, Emilio <Emilio.Lahr-Vivaz@anonymised.com> wrote:
Emilio
To: Jody Garnett <jody.garnett@anonymised.com>
Hi Jody.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Thoughts?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
That is an email best sent to geoserver-security email list (where we figure out such stuff).
For more information please see our security policy https://github.com/geoserver/geoserver/security
Jody Garnett
Apologies - since the upstream CVEs are already public, I didn’t realize it was necessary to keep the discussion private.
Emilio Lahr-Vivaz
Sent: Thursday, May 30, 2024 11:14 AM
To: Lahr-Vivaz, Emilio Emilio.Lahr-Vivaz@anonymised.com
Cc: GeoServer geoserver-devel@lists.sourceforge.net; Andrea Aime andrea.aime@anonymised.com; Gabriel Roldan gabriel.roldan@anonymised.com
Jody Garnett
On May 30, 2024 at 8:00:00 AM, “Lahr-Vivaz, Emilio” <Emilio.Lahr-Vivaz@anonymised.com> wrote:
Hey guys,
Emilio Lahr-Vivaz
To: Gabriel Roldan <gabriel.roldan@anonymised.com>
Hi Gabriel,
  • cog-aws
  • cog-azure
  • cog-google
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
On Thu, May 30, 2024 at 4:38 PM Gabriel Roldan <gabriel.roldan@anonymised.com7…> wrote:
camptocamp
Gabriel Roldán
Emilio
Emilio Lahr-Vivaz
Hi Emilio,
I’m all for it!
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Emilio
Hi Jody.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Thoughts?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Geoserver-devel@anonymised.comsourceforge.net
Apply accepted, we are all learning a good way forward.
Even if a library has a public CVE it may or may not be exploitable from geoserver user interface or web service; or may be limited to a specific extension etc…
If a CVE in a dependency does affect geoserver we make a CVE for our project, if not we just update the dependency.
Folks get very worried about vulnerabilities so public discussion is EXPENSIVE. With regulation requirements taking shape in Europe and the US it is becoming even more expensive.
Jody Garnett
pull request applying all of the above can be found here:
https://github.com/geoserver/geoserver/pull/7710
I think it makes working with assemblies much nicer/cleaner in general.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
