Dear all,
I'm in the specification phase for a simple mobile GeoServer client
based on Android (Java).
I think there exist some WMS viewers but:
Is there any application/project around which reads GeoServer
tilecache API preferrably in JavaSE/JavaME open source? (i.e. not
necessarily restricted to Android's Java)
Yours, Stefan
Hi Stefan,
There was some stuff in GeoTools for doing tiled WMS, but I think it may
have been removed. I am told it lives in udig now so it may be worth
checking out. Although i am not sure if it will be lightweight enough to
run on Android (fully admitting i am ignorant to what limitations are
placed on Java).
-Justin
On Sat, 17 Oct 2009 14:16:34 +0200, Stefan Keller <sfkeller@anonymised.com>
wrote:
Dear all,
Yours, Stefan
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Many thanks, Justin!
And I assume the GeoWebCache option available in GeoServer is some
sort of implementation of OGC's WMTS tile cache document (draft)?
Yours, Stefan
2009/10/18 Justin Deoliveira <jdeolive@anonymised.com>:
Hi Stefan,
placed on Java).
-Justin
wrote:
Dear all,
Yours, Stefan
Justin Deoliveira
GWC 1.2.0 will support WMTS (the version that OGC is voting on now, currently only the KVP scheme), so you can grab a nightly if you need it now. It'll probably make its way into GS 2.0.1.
Note that WMTS is a pain to configure manually unless you use one of the "well known scale sets", and the getcapabilities document for automatic configuration is rather verbose. I haven't checked how good the latest generation of phones is at parsing XML, can't be too bad since they render HTML locally, but it's something to keep in mind.
Couple of other thoughts:
If spherical mercator is sufficient, then you can use any MS Virtual Earth (quadkeys) or Google Maps (x,y,z template) compatible client as well.
-Arne
Yours, Stefan
Hi Stefan,
placed on Java).
-Justin
wrote:
Dear all,
Yours, Stefan
Arne Kepp
Expert service straight from the developers
Hi Stefan,
you may want to take a look at gvSIG Mobile: <http://www.gvsig.org/web/projects/gvsig-mobile/gvSIG-Mobile-en/view?set_language=en>
There seems to be a port to Android in progress: <http://tinyurl.com/yhknpnb>
Gabriel
Dear all,
Yours, Stefan
developing skills, take BlackBerry mobile applications to market and stay ahead of the curve. Join us from November 9 - 12, 2009. Register now!
Gabriel Roldan
