[Geoserver-devel] Time to declare JDK 17 as supported, rather than experimental?
now that the bin and windows installers should be working out of the box on a Java 17,
is it time to remove the “experimental” qualification from the production page?
https://docs.geoserver.org/latest/en/user/production/java.html
“Java 17 - GeoServer 2.22.x and above (OpenJDK tested, experimental only)”
I would also add “Java 21 - GeoServer 25.x and above (OpenJDK tested, experimental only)”
since we have the builds, but not a widespread usage.
I believe GeoServer Cloud defaults on it, but the number of deploys is limited.
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Next release cycle? Or is it backported …
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Hi Jody,
good point! The Marlin fix was backported to 2.25.x, but not to 2.24.x.
It could be done with the 2.26.0 release and extended to 2.25.x I guess?
There is nothing else Java 17 specific that needs to be done, and in case one has
trouble, there are the JVM flags documented in the guide that can be added to work around it.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
I was thinking about these two pages:
https://geoserver.org/download/
What should they say when we are done :slight_smile:
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Hi Jody,
notes inline below:
Does not have a mention of a java version, don’t think it needs one. The minimum java version
is considered in the second page you mentioned.
I would make the Java 17 line look like:
“Java 17 - GeoServer 2.25.4 and above (OpenJDK tested), but also 2.22.x and above in an experimental way (the windows installer and bin packages need tweaks)”
or just simplify the message and say:
"Java 17 - GeoServer 2.25.4 and above, (OpenJDK tested)
I would also add a new line:
The download page archive tab lists each version and version of Java used. They have not yet changed on a point release.
Jody Garnett
I don’t know how that page is generated but… if it’s a big problem,
we can just declare Java 17 supported for 26.x onwards and simplify things.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
It is just some code here:
https://github.com/geoserver/geoserver.github.io/blob/ed3b92af50c938adb55c61330714358fe75e9ddc/download/index.html#L259-L270
We should probably adjust it as so Java 17 is only shown for 26.x (to respect Java 17 being “experimental” presently).
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
