[Geoserver-devel] time to live for geoserver layer
I write to know if you develop a temporary layer, deleting after a fixed period.
My idea is to create a layer and set the time to live for it, after this period I delete from Geoserver the layer and optionally the data from filesystem or database.
If the user want to maintain the layer, he can set the layer time at -1.
I need this functionality because I created a wps that calculate temporary layers and upload this on Geoserver for viewing, but the result layer could be interesting or not, if the client show interest, he can save him with time to live at -1.
Any suggestion?
Thank you very much and sorry for my bad English
Samanta
Le informazioni contenute in questo messaggio di posta elettronica sono riservate e confidenziali e ne e’ vietata la diffusione in qualsiasi modo o forma. Qualora Lei non fosse la persona destinataria del presente messaggio, La invitiamo a non diffonderlo e ad eliminarlo, dandone gentilmente comunicazione al mittente.
The information included in this e-mail and any attachments are confidential and may also be privileged. If you are not the correct recipient, you are kindly requested to notify the sender immediately, to cancel it and not to disclose the contents to any other person.
Die Informationen in dieser E-Mail-Mitteilung sind vertraulich und deren Verbreitung in jeglicher Art oder Form ist untersagt. Sollten Sie diese Nachricht irrt?mlich erhalten haben, ersuchen wir Sie, sofort den Absender dar?ber zu informieren und die Mail zu l?schen.
http://www.dedagroup.it
On Tue, Sep 9, 2014 at 11:03 AM, <Samanta.Biasiolli@anonymised.com> wrote:
period.
time to live at -1.
Any suggestion?
Seems like a job for an extension, you could put the time to live flag
in the layer metadata map, listen to catalog events to catch the layers
that have the flag (and keep their ids in a list or some storage for fast
lookup), then have a timer that polls from this list and checks which
layers need to be expired.
To remove the data you can use DataStore.removeSchema, mind it
has been recently added, so not all stores support it (JDBC ones
do for example) and generally speaking the code doing that is
kind of new.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
