[Geoserver-devel] Time to upgrade Spotless... and maybe take advantage of the break?
you probably know that we are formatting the source code with the Spotless Maven plugin,
in combination with the Google Java Format library.
Currently, we are using an older version of both, because they upgraded time ago to require Java 11 as the minimum version, and we were still using Java 8. But we have been on Java 11 for a while now, and we can update up the dependencies.
I’ve prepared a pure upgrade of GeoTools, as an example, here:
https://github.com/aaime/geotools/tree/spotless_upgrade
The update touches 2k files, mostly changing the javadoc style for single line javadocs, to use three lines instead. Lots of noise, no significant gain in my opinion.
One formatting library that I’ve been keeping an eye on for a while is Palantir’s fork of Google Java format. They made some significant changes:
In this case, the GeoTools diff is significantly bigger than the pure Spotless upgrade, touches 2k files, but in the end, manages to cut down 60k lines of code.
What is your opinion? Would you like to go with Palantir?
If we went down that road, I’d recommend to:
  • Wait until the Wicket 9 upgrade is done
  • Wholesale reformat all three projects (GeoTools, GeoWebCache, GeoServer)
  • Reformat all active branches for ease of backport (if this ends up landing after the 2.25.x release, maybe also reformat the 2.23.x series as it will likely get some extra fixes in the next few months).
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Sounds good to me, not too bothered by which one we go with.
Ian
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
I really like the more terse alternative and longer line width.
Since I like two things +2 :slight_smile:
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
That plan sounds good to me. I’ve been using a 120 char line length on other projects, and it’s been good, so +1 to the Palantir format.
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
