[Geoserver-devel] TR : Geoserver Security Bbox management
Could you share the details on how you extended the security configuration files
to put in them the info about the allowed bbox ?
I had to use many dataSource (like xml,bdd and ldap) and our right extended (layer,bbox(s),service,request,filters etc are linked together in the geoRM) so I wrote my own system and I think it would not be usefull for you.
I didn’t use properties file like in org.geoserver.security.DefaultDataAccessManager in order to correct the problem with ‘.’ in coordinate, I used xml (and avoid properties files). I created DTOs (my own enveloppe) and for serialization/deserialization I used Xstream (which is in geoserver too):
If you want one Bbox for one role and layer: (with xstream and alias you have object direcly:)
test
-8236345.031824412
-8236346.031824412
4968280.5516899815
4971290.776477601
EPSG:900913
</right
auth = (Authentication) SecurityContextHolder
.getContext().getAuthentication();
protected int vote(org.geoserver.platform.Operation op, Authentication user) {
GetMapRequest getMapRequest = (GetMapRequest) op.getParameters()[0];
MapLayerInfo layersInfo = getMapRequest.getLayers();
org.geotools.geometry.jts.ReferencedEnvelope env = new ReferencedEnvelope(
getMapRequest.getBbox(), getMapRequest.getCrs());
MyBbox bbox=bboxManagerOrDao(auth.getGrantedAuthorities()[0],layersInfo[0]);
ReferencedEnvelope env2=new ReferencedEnvelope(bbox.getX1(),bbox.getX1() , bbox.getX1() , bbox.getX1() ,bbox.getCRS());
env2=env2.transform(getMapRequest.getCrs(), true);
boolean isIn=env2.contains((BoundingBox)env));
I can’t do more
Fabien
Ce message et les pièces jointes sont confidentiels et réservés à l’usage exclusif de ses destinataires. Il peut également être protégé par le secret professionnel. Si vous recevez ce message par erreur, merci d’en avertir immédiatement l’expéditeur et de le détruire. L’intégrité du message ne pouvant être assurée sur Internet, la responsabilité du groupe Atos Origin ne pourra être recherchée quant au contenu de ce message. Bien que les meilleurs efforts soient faits pour maintenir cette transmission exempte de tout virus, l’expéditeur ne donne aucune garantie à cet égard et sa responsabilité ne saurait être recherchée pour tout dommage résultant d’un virus transmis.
This e-mail and the documents attached are confidential and intended solely for the addressee; it may also be privileged. If you receive this e-mail in error, please notify the sender immediately and destroy it. As its integrity cannot be secured on the Internet, the Atos Origin group liability cannot be triggered for the message content. Although the sender endeavours to maintain a computer virus-free network, the sender does not warrant that this transmission is virus-free and will not be liable for any damages resulting from any virus transmitted.
Cellier Fabien wrote:
Could you share the details on how you extended the security configuration files to put in them the info about the allowed bbox ?
I understand, I'd like doing something more general, for it to be used by the whole community... if it is accepted, that is.
I didn't use properties file like in org.geoserver.security.DefaultDataAccessManager in order to correct the problem with '.' in coordinate, I used xml (and avoid properties files). I created DTOs (my own enveloppe) and for serialization/deserialization I used Xstream (which is in geoserver too):
I can't do more
You already did a lot: Thanks for you kind help !
    Luca Morandini
www.lucamorandini.it
