[Geoserver-devel] Travis _JAVA_OPTIONS
Travis started setting _JAVA_OPTIONS, which overrides our Maven memory settings and puts us again at risk of random build failures:
https://docs.travis-ci.com/user/build-environment-updates/2017-09-06/
I have removed _JAVA_OPTIONS in .travis.yml on supported branches of GeoTools and GeoServer.
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
My fix is ineffective. Success depends on how the age of the Travis worker image. The newer workers fail:
Builds on these images succeed:
Build image provisioning date and time
Fri Jul 7 18:52:25 UTC 2017
Builds on these images fail:
Tue Aug 29 02:50:02 UTC 2017
It is a lottery. Affects both GeoTools and GeoServer and all branches.
Kind regards,
Ben.
Director
New Zealand
I have applied a new fix to all of the branches. My original fix was likely getting overwritten by some undocumented Travis stage order. Initial tests indicate that the new fix works on the new (August) Travis worker images. It is not needed on the old ones but does no harm.
Of all places I found the fix in some sort of Japanese aggregator. I wish Travis would put this in their documentation:
https://www.ctolib.com/article/comments/461
Use new Travis image with _JAVA_OPTIONS unset
Per Travis support:
   As part of the Trusty image updates we've capped Java memory by setting
   the _JAVA_OPTIONS environment variable, which seems to be interfering
   with your build. Since you are running in our sudo:required environment
   and your build is memory-heavy, I'd suggest unsetting this (it was
   mostly aimed at our users running Java inside Docker). For example,
   adding "before_install: unset _JAVA_OPTIONS" should do the trick.
Kind regards,
Ben.
Kind regards,
Ben.
Director
New Zealand
Ben you are stubbornly learning so much about travis; could we write down some care and feeding instructions for these tricks for the developers guide? Or is tarvis too much of a moving target …
On 11 September 2017 at 19:56, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Per Travis support:
As part of the Trusty image updates we’ve capped Java memory by setting
and your build is memory-heavy, I’d suggest unsetting this (it was
adding “before_install: unset _JAVA_OPTIONS” should do the trick.
Kind regards,
Ben.
Kind regards,
Ben.
Director
Transient Software Limited <http://transient.nz/>
New Zealand
GeoTools-Devel mailing list
GeoTools-Devel@anonymised.comge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Jody Garnett
So far our Travis problems have been different every time. The Travis documentation is pretty good. The solution is usually to read the logs and use The Google.
Kind regards,
Ben.
guide? Or is tarvis too much of a moving target ...
Jody Garnett
Per Travis support:
Kind regards,
Ben.
Kind regards,
Ben.
Director
New Zealand
Check out the vibrant tech community on one of the world's most
GeoTools-Devel@lists.sourceforge.net
Director
New Zealand
