Trying out GeoServer without vecmath (the geotools “matrix” branch). I expect quite a few test cases to change based on difference matrix implementation. I had two tests change in GeoTools:
a) one based on different invert() results, needed to adjust tolerances to recognize result as an Identity matrix after calculation involving matrix. So very subtle differences in inverse() output - not sure which implementation was more accurate.
b) one based on transforming WMS lat/lon bounds to native bounds resulting in slightly different output. The transformation chain was epic so I am not surprised at the slight difference near the poles. It is this difference that has me expecting changes at the GeoServer level.
So far all I have noticed is the pom.xml references OpenPlans still, changing that to OSGeo
testRasterKeepNative(org.geoserver.wms.wms_1_1_1.GetFeatureInfoTest) Time elapsed: 28 sec <<< FAILURE!
java.lang.AssertionError
at org.junit.Assert.fail(Assert.java:86)
at org.junit.Assert.assertTrue(Assert.java:41)
at org.junit.Assert.assertTrue(Assert.java:52)
at org.geoserver.wms.wms_1_1_1.GetFeatureInfoTest.testRasterKeepNative(GetFeatureInfoTest.java:816
And again:
testRasterKeepNative(org.geoserver.wms.featureinfo.GetFeatureInfoJSONTest) Time elapsed: 41 sec <<< FAILURE!
at org.geoserver.wms.wms_1_1_1.GetFeatureInfoTest.testRasterKeepNative(GetFeatureInfoTest.java:816)
And again:
This is odd as the test is trying to keep things in the native projection, which I assume would be less prone to differences due to reprojection.
// force it to “keep native”
CoverageInfo ci = getCatalog().getCoverageByName(getLayerId(CUSTOM));
ci.setProjectionPolicy(ProjectionPolicy.NONE);
getCatalog().save(ci);
And again:
Pull request available for the one regression with GetFeatureInfo (https://github.com/geoserver/geoserver/pull/1043).
While I would love feedback on the difference found (especially the visual difference) we are now ready to proceed.
And again:
