[Geoserver-devel] Unable to avoid day shift upon WFS-T Insert using GeoTools LOCAL_DATE_TIME_HANDLING hint
My proposed change is not right and may interfere with time parsing. But the problem is real. I see the XsLocalDateTime subclass and will look into isolating my change to that, with minor refactoring. That can hopefully lead to a pull-request to fix WFS-T Insert for date values with localDateTimeHandling=true.
Sent: Thursday, May 11, 2017 11:43 AM
To: ‘geoserver-devel@lists.sourceforge.net’ geoserver-devel@lists.sourceforge.net
Subject: Unable to avoid day shift upon WFS-T Insert using GeoTools LOCAL_DATE_TIME_HANDLING hint
It appears that when WFS executes a query, it correctly examines the localDateTimeHandling flag to avoid shifting the day back by one. But in the case of using WFS-T to insert a date, no such check is made and the day shifts when stored in the database. This results in the wrong day being reported in a subsequent query.
For example in my Oracle table I have an INSTALLED_DATE column of type DATE. My Oracle database has a dbtimezone of EST (-05:00:00 offset from GMT). I send a WFS insert transaction that populates the date as:
ov:INSPECTION_DATE2016-01-04</ov:INSPECTION_DATE>
If I then select the data in a sqlDev session, Oracle tells me the date is 03-Jan-16, where I would expect 04 instead of 03.
Then for grins I execute a WFS GetFeature with outputFormat=”JSON” and I see the date reported as “INSPECTION_DATE”:“2016-01-03”.
So, inserted 2016-01-04, query and get 2016-01-03.
I then changed the XsDateTimeFormat class as follows and apparently fixed this problem…I changed these lines:
if (parseTime) {
tz = TimeZone.getTimeZone(digits.toString());
} else {
// there’s no meaning for timezone if not parsing time
// http://en.wikipedia.org/wiki/ISO_8601
tz = TimeZone.getTimeZone(“GMT”);
My revised code reads as:
// Apply timezone arithmetic when z+/- has been used.
if (parseTime && digits.toString().length() != 3) {
// Set the timezone based on z+/- arithmetic in the time.
} else {
// Set the timezone for times or dates based on the default.
// Note that timezone does have meaning for dates because
// it facilitates handling the value as a date/time of
// midnight that day and timezone changes can adjust the
// value of the date itself.
Object hint = Hints.getSystemDefault(Hints.LOCAL_DATE_TIME_HANDLING);
if(Boolean.TRUE.equals(hint)) {
// Use the time zone of the JVM
tz = TimeZone.getDefault();
} else {
Thoughts on this as an acceptable mod?
Thanks – Walter Stovall
Byers Engineering Company
Sent: Wednesday, June 22, 2016 4:46 AM
To: Chris Buckmaster <chris.buckmaster@…4589…>
Subject: Re: [Geoserver-users] Time Zone issue with dates using GeoServer WFS
On Wed, Jun 22, 2016 at 9:50 AM, Chris Buckmaster <chris.buckmaster@…4589…> wrote:
The problem I am encountering is, for any dates that fall within British summer time (GMT Daylight Saving Time), it appears to be moving the actual date back by one day (i.e. for a date stored as 8th September 1993 in PostGIS, it is displaying as 07/09/1993 in my HTML / Javascript web application). The field is not a timestamp field, it is just a date field so from what I can gather it shouldn’t be storing any information on time zones?
There was a discussion about this topic on geotools-devel some time ago, the outcome was that yes, also dates have timezone (not hard to grasp,
e.g., now it’s Wednesday here in Europe, but in a few hours it will be Thursday in Australia). I believe that the outcome was also that it’s useful to add a configuration flag
for those that do not work in an international settings, so that the dates do not get modified in those cases.
According to the docs there is a system variable you can set:
http://docs.geotools.org/latest/userguide/library/metadata/geotools.html
So starting your JVM with -Dorg.geotools.localDateTimeHandling=true should change the behavior. It would be nice to have that as a global setting
in the GeoServer UI… anyone interested in coding it? :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
