On Wed, Oct 14, 2015 at 1:25 PM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
Geoserver 2.8 seems to run on Jetty 9.3.3 on Windows as I wrote earlier
today http://sourceforge.net/p/geoserver/mailman/message/34538787/.
I wonder what should be done for updating the Jetty version that is
included in the official releases. The start scripts need editing but is
there anything else? If that is something relatively simple I can try if I
could make an updated zip installer with Jetty 9.3.3 if it is a good
version to use.
The jetty minimal install files are found here:
https://github.com/geoserver/geoserver/tree/master/src/release/jetty
In order to update those would have to be replaced too. To test the
packacing, run at least one this:
mvn clean install -DskipTests -Prelease
to get all the jars built, and then to test your packacking, run:
mvn assembly:attached -nsu
and you will get the -bin package, from which the windows installer is
derived, in target/release (if memory serves me right).
The "hard" part is to figure out the minimum set of jar and config files
that make Jetty run,
keeping it small but functional.
Btw, personally I don't have any objection to moving to a minimized Tomcat
if needs be... of course
it's a larger change, but could be interesting for those that want to run
GeoServer in production
with just the windows installer.
That said, I'll take a Jetty upgrade any day, instead of nothing (like,
forget about me mentioning
Tomcat if that gets in the way getting anything done)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
