Hi all (Hi Justin),
I've tried to follow instructions to use the cite module
but I'm having troubles checking out the test sources.
When I follow this (from the README):
B. Get Test Sources
Create a directory called 'tests', and check out the cite test sources into
it.
'mkdir tests'
'svn co https://svn.opengeospatial.org:8443/ogc-projects/cite/trunk tests'
*Note* : You will need a user name and password for the cite subversion
repository. If you have a cite portal account, that will work.
Hum, I've tried both with the username/pw I use to access the
ogc portal and the one we use to access the online team engine, but
neither works. I guess I have to request an account... where?
Hi Andrea,
Unfortunately I am not exactly sure. I thought if you got an ogc portal
account you could use it... but mine does not work. I had to get someone
with a working account to check them out for me.
I should look into this further about how to get ogc svn access. For now
i would be happy to send you over some tests.
-Justin
Andrea Aime wrote:
Hi all (Hi Justin),
B. Get Test Sources
it.
'mkdir tests'
tests'
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-devel mailing list
!DSPAM:4007,479087d0285841030819293!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
