Here is dave's origional email .... I think it documented the work we lost in the Postgis 1.0 timeframe.
Actually looking at this - I think I made him change the id's to be strings (we need to "share" these strings between data sources - darn complicated wfs specification).
Jody
SQL:
CREATE FUNCTION lockcheck(TEXT,TEXT) RETURNS TRIGGER AS
'/data1/Refractions/Projects/PostGIS/work_dave/postgis/libpostgis.so.0.8'
LANGUAGE C;
CREATE TABLE geo_table (id int primary key,the_geom geometry, name text);
CREATE TRIGGER locktrig_geo_table BEFORE UPDATE OR DELETE
ON geo_table FOR EACH ROW
EXECUTE PROCEDURE lockcheck('id','geo_table_loc');
insert into geo_table values (1, 'POINT(0 0)', 'dave');
insert into geo_table values (2, 'POINT(1 0)', 'jody');
insert into geo_table values (3, 'POINT(2 0)', 'brent');
insert into geo_table values (4, 'POINT(3 0)', 'justin');
create table geo_table_loc (id int, lock_key int, expires date);
insert into geo_table_loc values (2, 666, '2100-1-1'); --loc row 2 with
lock id 666
BEGIN;
select have_lock_for(666);
select have_lock_for(667);
select have_lock_for(668);
update geo_table set name = 'nexus' where id =1; -- no lock here, so
its good
update geo_table set name = 'tenderflake' where id =2; -- error or ignore
COMMIT;
