[Geoserver-devel] Various fixes for GeoServer GUI + JDBCConfig plugin
I would like to submit to your attention the following pull request which contains various improvements on the GeoServer GUI, especially useful when the JDBCConfig plugin is active.
Here is the link to my pull request: https://github.com/geoserver/geoserver/pull/836.
These improvements can be noticed with an high number of Layers and stores configured.
The various improvements are quickly summarized here:
  1. Improved the performances of the LayerPreview
  2. Improved the StoreProvder class
  3. Improved the StyleProvder class
  4. Improved the performances of the LayerListPanel
  5. Reduced the GWC startup time by adding a lazy loading of the GeoServerTileLayers
  6. Fixed an issue on the SecuredCatalog which actually does not create a security filter for the Styles
  7. Changed the DefaultDataAccessManager into a DefaultResourceAccessManager
  8. For JDBCConfig plugin, improved the query construction and added a few nested properties for speeding up db queries.
I will be pleased to answer to your questions. For what concerns the modifications on the DefaultDataAccessManager, it should be better to ask Andrea which has worked on that class.
Thank you for your attention.
Nicola Lagomarsini.
Ing. Nicola Lagomarsini
Junior Software Engineer
Via Poggio alle Viti 1187
On Fri, Nov 28, 2014 at 8:11 PM, Nicola Lagomarsini <
Well, in short, that complex security filter function was actually
necessary... but it was not impossible to remove and optimize.
The thing is, it was there because the default security subsystem of
GeoServer was still using a DataAccessManager.
To fix thing, I've upgraded that class to become a
DefaultResourceAccessManager, and build security filters according to
the security tree structure, and paying attention to keep the filters
encodable:
https://github.com/geosolutions-it/geoserver/blob/fixGUIPerformances/src/main/src/main/java/org/geoserver/security/impl/DefaultResourceAccessManager.java#L252
In order to achieve that, I've also had to add support for
PropertyIsNotEqualTo in the filter to sql encoder (which declared such
support, but did not
implement it).
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
