I would like to propose adding a web user interface for adding, editing, and deleting scripts to the community script module. This is my first foray into wicket development, but I have a branch that includes a page that lists scripts, a page that can add new scripts, and a page that can edit scripts.
It sounds like a good idea, I do have some feedback on the UI design (I know it is similar to the style editor design).
I would like to see the text editor near the top of the page, so we do not have to scroll so much. Could the extra name/type/extension information be moved to the right of the text area (as we have wider monitors now?
The Submit / Canel both take you back to the list of scripts. This is a pain when debugging, can we add a “Apply” button which saves and leave you on this page? Or perhaps “Apply”, “Save” and “Cancel” buttons allowing the work to be saved (and tested in another window) while leaving this page editing the current script.
I can create a Jira ticket and send a pull request if this sounds like a good idea.
Jared
Is your legacy SCM system holding you back? Join Perforce May 7 to find out:
� 3 signs your SCM is hindering your productivity
� Requirements for releasing software faster
� Expert tips and advice for migrating your SCM now http://p.sf.net/sfu/perforce
On Thu, May 8, 2014 at 4:48 AM, Jared Erickson <jared.erickson@anonymised.com>wrote:
Hi all!
edit scripts.
On Thu, May 8, 2014 at 5:37 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Hi Jody,
everything in the CSS is setup for a single column design, making stuff
align in any other way
is hard, we had to curse quite a bit just to get the envelope editor look
the way it looks without
using tables to lay it out (which would have been a 2 minutes job, but then
designers would have
asked for our head...)
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime @geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Jody,
everything in the CSS is setup for a single column design, making stuff align in any other way
is hard, we had to curse quite a bit just to get the envelope editor look the way it looks without
using tables to lay it out (which would have been a 2 minutes job, but then designers would have
asked for our head…)
Ing. Andrea Aime
@geowolf
Technical Lead
Regarding the textarea / text editor, is it using code mirror? Be nice if we could get the syntax highlighting and other nice features of code mirror. We use it for the SLD editor and if I remember it isn’t too difficult to wire up with wicket.
Good to know I was getting stuck trying to do that for the style legend graphic patch.
Hi Jody,
Ing. Andrea Aime
@geowolf
Technical Lead
Please correct me if I’m wrong, its an “editor” for referenced scripts to modify these via browser, right?
I was wondering whether geoserver could have a scripting console for GeoServer instance itself, where the admin could hav script access to modify settings of layers, datastores, workspaces, users, etc.
A similar and really effective way to administrate an instance does Jenkins/Hudson have (https://wiki.jenkins-ci.org/display/JENKINS/Jenkins+Script+Console). The user/admin have access to the whole model and can change settings/configurations via Groovy.
Wouldn’t that be a nice improvement for GeoServer Community?
Hi Jody,
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Jody,
Ing. Andrea Aime
@geowolf
Technical Lead
I am not using CodeMirror yet. I did have it working but it only did XML syntax highlighting. Do you know what version GeoServer is using? I couldn’t figure it out. Also, what do you think about upgrading the CodeMirror JS library? Recent versions support all modern browsers and IE back to version 8.
Hi Jody,
Ing. Andrea Aime
@geowolf
Technical Lead
On Sat, May 10, 2014 at 4:14 AM, Jared Erickson <jared.erickson@anonymised.com>wrote:
Hi Justin!
I don't know the version either, but it has committed back in Nov 2010, so
it's 3.5 years old.
Upgrading would be great, just make sure the sld editor and the demo
request pages keep on working fine
Technical Lead
Sorry for the delay, but I am the world’s slowest wicket developer. I finally have CodeMirror working as the editor for scripts (see attached). This required upgrading CodeMirror to version 4.1 (the latest) which supports all modern browsers and IE 8 and above (http://codemirror.net/#browsersupport). I have tested the upgraded CodeMirror on FireFox, Chrome, and Safari on OS X. I haven’t tested on IE yet. If these proposed changes seems acceptable how would you like me to structure the pull requests? I see two alternatives:
#1
CodeMirror Upgrade
Script UI using CodeMirror
#2.
Script UI using text area
CodeMirror Upgrade
The only reason to go with #2 is if the CodeMirror upgrade is problematic.
I don’t know the version either, but it has committed back in Nov 2010, so it’s 3.5 years old.
Upgrading would be great, just make sure the sld editor and the demo request pages keep on working fine
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, May 14, 2014 at 5:25 AM, Jared Erickson <jared.erickson@anonymised.com>wrote:
supports all modern browsers and IE 8 and above ( http://codemirror.net/#browsersupport). I have tested the upgraded
#1
1. CodeMirror Upgrade
2. Script UI using CodeMirror
#2.
1. Script UI using text area
2. CodeMirror Upgrade
3. Script UI using CodeMirror
The only reason for concern is that, I believe, the version we're currently
using supports IE down to version 6 (support for which was dropped around
2012).
I guess it would be nice/useful if the code could recognize the browser
version and fall back on a plain text area in case the
browser is not supported.
Maybe you go with 2, make the pull request for the code mirror upgrade, and
allow other people to help you with the above?
Technical Lead
The code mirror upgrade happened and I updated the script editor pull
request so now we have syntax highlighting. Any chance this could get
accepted before the upcoming feature freeze?
