Hi David, andrea
b) When I proxied geoserver, I couldn’t save most configuration options (i.e. change the logging profile)
- it would give me a “Origin does not correspond to request” error
- others recommended setting “-DGEOSERVER_CSRF_DISABLED=true”
- this worked, but now if I change the logging profile it will log me out (but my changes were saved).
Hum… not sure, I’ll inquire with Alessandro on how the proxying is set up.
I understand this is an unrelated problem with your local environment David. I suggest you check your PROXY_BASE_URL settings.
In terms of proxy config there is nothing special honestly… we’re using Nginx with an explicitly set PROXY_BASE_URL:
And we are passing the X-Forwarded-** headers from Nginx to GeoServer. That info should be used by GeoServer to understand
what protocols and host are used by the user to connect to it.
We can have a closer look but before we do that are you sure you cannot reproduce it locally on an HTTPS setup?
Thank you,
Alessandro
On Thu, Sep 29, 2022 at 9:46 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Sep 29, 2022 at 1:05 AM David Blasby <david.blasby@anonymised.com> wrote:
Andrea,
I tried to reproduce this and found some more issues;
a) I couldn’t “cd web/app; mvn jetty:run”
- I get a nullpointerexception - likely because there’s no settings in global.xml
- i used data/release and it worked fine
Uh yeah, this is bad… GeoServer should be able to start off a completely empty data directory (eventually
with some warning). I thought we had a test to that effect, but I cannot find it…
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Geoserver-devel mailing list
Regards, Alessandro Parma == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Alessandro Parma DevOps Engineer GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) Italy phone: +39 340 4752467 fax: +39 0584 1660272 https://www.geosolutionsgroup.com https://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
