[Geoserver-devel] WFS schema location: why not canonical URL?
Is there any reason why WFS responses include a WFS schemaLocation URL that points back to the server, and not the canonical location?
At the moment a WFS 1.1.0 response includes this:
xsi:schemaLocation="http://www.opengis.net/wfs http://localhost:80/geoserver/schemas/wfs/1.1.0/wfs.xsd [...]"
I would prefer the canonical location:
xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd [...]"
The canonical location is more likely to be cached by a validating client, and can be easily recognised as a WFS 1.1 response without having to fetch and parse the server's copy, which may or may not be the same.
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
Hi Ben,
This has come up a few times in the past and the general idea is that using a canonical url would require wfs clients to have an internet connection in order to parse a wfs response. Which was decided would be too restricting.
What probably should do is add some sort of flag to allow server admins to control this.
-Justin
Kind regards,
Justin Deoliveira
OpenGeo - http://opengeo.org
It should should be default ("truth in advertising")
app-schema always uses the correct url for the configured schema
anonymous schema always uses a introspective data-store derived schema
from the WFS
clients using XML, a web technology, without a web connection need to
use the standard XML archiecture - in this case OASIS catalogs.
This is simpler than using a flag or adding burden on admins to get it
right IMHO.
Rob
On Tue, Dec 15, 2009 at 2:39 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Ben,
too restricting.
to control this.
-Justin
same.
Kind regards,
Justin Deoliveira
Return on Information:
Google Enterprise Search pays you back
Get the facts.
http://p.sf.net/sfu/google-dev2dev
Geoserver-devel mailing list
We should check that the OGC is ok with this. I think originally we moved it to serving it up ourselves since the OGC one wasn't reliable. Or maybe they weren't even serving it at all? We've got a decently big user base, so we might increase the traffic there not insignificantly. I'm not opposed to it, but this is the first complaint we've got about it, and I'm not convinced that there's going to be much of a performance gain for many clients. And I'm generally of 'if it's not broke don't fix it'.
from the WFS
right IMHO.
Rob
Hi Ben,
too restricting.
to control this.
-Justin
same.
Kind regards,
Justin Deoliveira
Get the facts.
Get the facts.
Chris Holmes
Opps : I am mixing up issues here - sorry, Ben was talking about the
WFS and other OGC schemas.
This is the same issue for GML: internally we use the real location
and a cached copy - IMHO we should always do this - and promote the
need for clients to do the same otherwise things will break somewhere.
(you cant use GML without a local cache and a catalog IMHO).
I would suggest equirements:
*) All Geoserver schema use (e.g. configuration, validation, parsing)
needs to use local caches consistently
*) Good documentation to inform users.
*) "truth in advertising" - give clients an opportunity to use _thier_
caches by using the canonical URLs
Rob
On Tue, Dec 15, 2009 at 10:35 AM, Chris Holmes <cholmes@anonymised.com> wrote:
from the WFS
right IMHO.
Rob
wrote:
Hi Ben,
too restricting.
to control this.
-Justin
same.
Kind regards,
Justin Deoliveira
Get the facts.
Get the facts.
Chris Holmes
from the WFS
The wfs spec makes no mention of supporting an OASIS catalog. To be truthful I wrote the wfs 1.1 reference implementation and I don't even know what an oasis catalog is.
I also don't think that telling people who are using geoserver on an internal network with no internet connection that "use an oasis catalog" is an acceptable upgrade path.
2c.
-Justin
right IMHO.
Rob
Hi Ben,
too restricting.
to control this.
-Justin
same.
Kind regards,
Justin Deoliveira
Get the facts.
Justin Deoliveira
The major reason we don't do this is the same reason we don't reference the openlayers online version in the map preview. It is not that we don't want the overload servers it is that downloading external resources would make the client unacceptably slow. Imagine downloading the entire GML3 schema over a slow internet connection, it would be a nightmare.
I know that app-schema uses its own internal schema cache. I don't think people would be adverse to using this cache everywhere in GeoServer but this is an idea that has never been brought up and I don't think anyone but Ben and Rob know how it works.
The first step would be to start socializing that idea among developers. And saying that what we do now is wrong and clients should change to use "standard XML architectures" is not really the way to do that. A concrete proposal stating what the changes are, why we want to make them, and what the considerations are in terms of backwards compatibility, performance, etc... is the way to do it.
-Justin
from the WFS
right IMHO.
Rob
Hi Ben,
too restricting.
to control this.
-Justin
same.
Kind regards,
Justin Deoliveira
Get the facts.
Get the facts.
Justin Deoliveira
Good to have this debate - wasnt aware the extent to which its not out
in the open, as the decision to use a local gml schema cache was
before my time I was perhaps being presumptious about people being
aware of the design decisions.
first and foremost I'd argue for consistency to simplify user
experience and maximise system robustness.
If users (or their client software) use GML they will be either
avoiding any schema references, or using a local cache. I would expect
this would hold for the interface as well as the payload. So I would
presume that no-one is using the WFS schema location for validation
that couldnt handle the canonical location - but I agree that testing
the waters and finding out what people do would be the place to start,
then we can work out what impact any changes may have.
Maybe a survey on the user's list? We could perhaps also look at logs
of demo servers and see what type of clients actually access these
locations?
Rob
On Tue, Dec 15, 2009 at 10:54 AM, Justin Deoliveira
-Justin
from the WFS
right IMHO.
Rob
wrote:
Hi Ben,
too restricting.
to control this.
-Justin
the
same.
Kind regards,
Justin Deoliveira
Get the facts.
Get the facts.
Justin Deoliveira
There's the (reasonable) assumption that a client needing to download the schemas at some time for parsing/validation would have a nicer time by downloading them directly from the server than from the canonical online resource. Both for speed and to avoid an unavailable online server from preventing you working (schema.opengis.net happened to be down a couple times actually).
This is course may not hold true for all cases. It would certainly do for intranet users, for internet users nothing tells downloading from geoserver would be faster, but certainly more reliable as you're already working against the server.
That said, I see the value in using canonical URL's for schema locations.
But that doesn't even help for one of the most common use cases: user downloads a wfs FeatureCollection and saves it as a gml file. Then wants to use that file in another software. The server still needs to be up/reachable to get to the featuretype schema, which _is_ server dependent. At least one takes the time of downloading the schema too and editing the gml file to make the schema location a relative reference...
Besides that, for WFS only most of the client software are desktop applications? can't really know, but I doubt setting up an xml catalog for a web browser is that easy, if it exists at all.
But still I see why using an OASIS Catalog where possible is valuable. GeoTools most of the time avoids downloading schemas at all since it have them in the jars. For the case of app-schema, this wasn't enough because not the whole schema types/elements were bound to GeoTools so not using an OASIS Catalog meant the GML schemas needed to be downloaded everytime you use it, and the performance penalty was terrific. It also had to permanently download GeoSciML schemas, etc.
All that said, what I'd like to see is a geotools module that produces a jar file containing all the used schemas from schemas.opengis.net and also provides an OASIS Catalog that hooks seamlessly in the geotools parser/encoder, and can also be used by any application using geotools.
Then a switch in GeoServer to use canonical/custom schema locations whose default preserves the current behaviour.
We could certainly do all of that, but it's not going to be trivial and I'm not seeing the gain clearly. Sounds like the effort is greater than the value to me, at least there's more compelling reasons. That is, I'm pretty sure client software is NOT using xml catalogs. If they wanted to use an OASIS Catalog though, they could just as easily add an entry for the geoserver location so it can still use the cached copy without changing a line of code in geoserver?
Gabriel
from the WFS
2c.
-Justin
right IMHO.
Rob
Hi Ben,
too restricting.
to control this.
-Justin
same.
Kind regards,
Justin Deoliveira
Get the facts.
Gabriel Roldan
You make some good points
Basically, if you follow schema URLs,
   * then you cant rely on the server being there
   * you can point the client at the server to get the schema if the
mechanism exists
   * it will be a pain if the canonical URLs are not used, as you will
have to fetch them every time you use a new server
Web browsers and non-validating clients do _not_ use schemas, so are
unaffected by any change.
The question still stands IMHO - is there any usage of the local
version by clients? You cant use an XML tool without an OASIS catalog
IMHO, and run-time validation is not common in other clients.
I think from here we should follow Andreas suggestion and have a
configuration flag to force use of canonical URLs, and start to
engineer in Gabriel's solution of a universal schema caching and
resolving capability, as opportunities permit.
I'd argue that theuse_canonical_schema_locations flag ought to be
default=true unless we can find evidence of real world clients using
the local references that will break.
Rob
On Wed, Dec 16, 2009 at 6:10 AM, Gabriel Roldan <groldan@anonymised.com> wrote:
times actually).
against the server.
Gabriel
from the WFS
2c.
-Justin
right IMHO.
Rob
wrote:
Hi Ben,
too restricting.
to control this.
-Justin
the
same.
Kind regards,
Justin Deoliveira
Get the facts.
Gabriel Roldan
This is my plan. I also intend to take it further and allow schemas to be packaged and released as a maven artifact to support offline testing. I would like to package GeoSciML 2.0, GeoSciML 2.1, and GeoSciML 3.0. I also intend to support on-demand caching of schemas so users can configure an app-schema instance with schemas unknown to the developers, and have the software automatically fetch and cache it. No more manual cache construction. Let the software do the work.
[Rob A: see SISS-561 in the cgsrv1 Jira]
