[Geoserver-devel] Where to put extensions in the user manual?
Mike,
I would like your editorial opinion. Some while ago I put the app-schema docs in the data section of the user manual. Should all data sources go there, whether they are extensions or not? Or should extensions all be in the extensions section? Other extensions hiding out in the data section include ArcSDE, so we are in good company. :slight_smile:
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Exploration and Mining
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
Hi Ben. A while back, I believe it was Justin and I that decided (very informally) that we would put all of the datastore/coveragestore extensions in the Working With Data section, and the non-store extensions (Charts, etc) in the Extensions section. Thinking about it now, I think it wouldn't be amiss to have a note in the Extensions section linking back to the Working With Data section, saying "hey, are you looking for the ArcSDE plugin? You want to be over here..." But that's an easy fix.
As usual, I am very open to suggestions on improving this workflow...
Mike Pumphrey
OpenGeo - http://opengeo.org
Ben Caradoc-Davies wrote:
Mike,
Kind regards,
