Perhaps I am being silly, I was under the impression that JTS slurped up WKB (in addition to the branch of our SDO implementation) as part of their new "io" modules.
Jody
Oops, sorry about that, i commited a local modification that i should not
have. The reason I didn't publish the jar was that I wasn't sure about any
IP issues or anything like that. But it seems the wkb4j project is dead so
I doubt there will be any issues.
I also plan to take a look at Postgis this week to remove the dependency.
-Justin
On Wed, September 20, 2006 3:39 am, Andrea Aime wrote:
Yes, it does. And we are using it. But Justin tried to remove the library and there were problems, so we need to go back and remove all references to it.
Chris
Jody
references to it.
Chris
Jody
opinions on IT & business topics through brief surveys -- and earn cash http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV
Sorry, I'm still seeing the same problem...
My eclipse projects aren't properly setup because of a dependency
onto that jar.
Maybe you forgot to commit the fix?
references to it.
Chris
Jody
I only made the change on geotools trunk. It is a significant change to
the module so i would like to run cite tests before making the change on
2.2.x.
-Justin
Andrea Aime wrote:
Justin Deoliveira ha scritto:
Done on trunk.
onto that jar.
references to it.
Chris
Jody
