[Geoserver-devel] WMS Aliasing
Hello all,
I'm trying to create a URL alias for the Geoserver WMS but am having trouble determining precisely how to do so; my googling has given me some similar results but nothing matching my current goals.
To explain; I would like to be able to reach the WMS via both <server>/wms/ and <server>/customTag (or <server>/wms/customTag) so that special request/response handling could be performed when sent via the customTag, but not when sent usually. This seems similar to the namespace concept, but I would want the same layers and workspaces visible from either address (and, indeed, would prefer to keep workspace functionality on top of the customTag endpoint).
I suspect this is easy to do and I've just somehow missed the document outlining the process. Anyone able to share some insight into how best this could be accomplished?
Thank you,
David Marks
On Thu, Jan 22, 2015 at 8:00 PM, Marks, David <David.Marks@anonymised.com>
wrote:
Hello all,
Hum no, as far as I know this functionality is not supported, but it shoud
not be too hard to get
writing your own servlet filter?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi David,
One idea: if you have a frontend proxy (eg. nginx) it can pull out the customTag, put it in a header which is then passed to GeoServer (eg, X-David: customTag), and then rewrite the GeoServer URL to /wms. Then you can access the header from the request object in GeoServer wherever you need it. If you need the value in responses as well (eg. GetCapabilities returning URLs including the “customTag” part), then you’ll need a URLMangler implementation to that knows how to rewrite URLs to contain it.
Rob :slight_smile:
On Fri, Jan 23, 2015 at 8:00 AM, Marks, David <David.Marks@anonymised.com> wrote:
Hello all,
I’m trying to create a URL alias for the Geoserver WMS but am having trouble determining precisely how to do so; my googling has given me some similar results but nothing matching my current goals.
To explain; I would like to be able to reach the WMS via both /wms/ and /customTag (or /wms/customTag) so that special request/response handling could be performed when sent via the customTag, but not when sent usually. This seems similar to the namespace concept, but I would want the same layers and workspaces visible from either address (and, indeed, would prefer to keep workspace functionality on top of the customTag endpoint).
I suspect this is easy to do and I’ve just somehow missed the document outlining the process. Anyone able to share some insight into how best this could be accomplished?
Thank you,
David Marks
New Year. New Location. New Benefits. New Data Center in Ashburn, VA.
GigeNET is offering a free month of service with a new server in Ashburn.
Choose from 2 high performing configs, both with 100TB of bandwidth.
Higher redundancy.Lower latency.Increased capacity.Completely compliant.
http://p.sf.net/sfu/gigenet
Geoserver-devel mailing list
Koordinates
PO Box 1604, Shortland St, Auckland 1140, New Zealand
Phone +64-9-966 0433 koordinates.com
