[Geoserver-devel] WMS tiling with EPSG:404000
Hi All,
I am using GeoServer 2.9.1. I have noticed the following behavior in WMS tiling for images (e.g. JPG as WorldImage) that have EPSG:404000. In the OpenLayers preview window, in single tile mode, the image looks fine. E.g.:
/uploads/default/original/2X/4/4cd6013dfc470a35f0641e2acd8b5dee5ac66c5b.png
However, when you switch to tiled mode, only one tile appears at the lower left . E.g.:
cid:image001.png@anonymised.com
Is this behavior expected? Is there any way to make tiling work properly in this case?
Thanks for any insight or advice you may have,
Scott
