The devel list is mostly reserved for Geoserver development. Developers are friendly people and they follow also the users list. If they do not answer soon it means that they are not only friendly but also busy. Via the users list you can meet also friendly users and have better possibility to get an answer soon. Users, even they are friendly, do not always know the answers. Neither did I when I sent an answer for your question when I asked you to test your process with data that you have captured from WFS with a separate call. I still think that it might give some more information about your problem and that would help the developers and advanced users with giving some helpful answer to you.
I compare your request with the example at
http://docs.geoserver.org/stable/en/user/extensions/wps/processes.html
I do not see any GetFeatures in your request. Are they supposed to be somewhere inside CDATA or what? Without knowing much about WPS I suppose that the process needs first some raw data before it can start processing.
-Jukka Rahkonen-
(attachments)
Samanta Biasiolli wrote:
I’m trying to call with a wps request an external wfs.
My request is:
ows:Identifiergs:Bounds</ows:Identifier>
wps:DataInputs
wps:Input
ows:Identifierfeatures</ows:Identifier>
<wps:Reference mimeType=“text/xml” xlink:href=“http://demo.opengeo.org/geoserver/wfs” method=“POST”>
wps:Body
<![CDATA ]>
</wps:Body>
</wps:Reference>
</wps:Input>
</wps:DataInputs>
wps:ResponseForm
wps:RawDataOutput
ows:Identifierbounds</ows:Identifier>
</wps:RawDataOutput>
</wps:ResponseForm>
</wps:Execute>
but I have this error:
Caused by: java.lang.ClassCastException: java.util.HashMap cannot be cast to net.opengis.wfs.FeatureCollectionType
Any suggestion?
Thank you very much
Samanta
Le informazioni contenute in questo messaggio di posta elettronica sono riservate e confidenziali e ne e’ vietata la diffusione in qualsiasi modo o forma. Qualora Lei non fosse la persona destinataria del presente messaggio, La invitiamo a non diffonderlo e ad eliminarlo, dandone gentilmente comunicazione al mittente.
The information included in this e-mail and any attachments are confidential and may also be privileged. If you are not the correct recipient, you are kindly requested to notify the sender immediately, to cancel it and not to disclose the contents to any other person.
Die Informationen in dieser E-Mail-Mitteilung sind vertraulich und deren Verbreitung in jeglicher Art oder Form ist untersagt. Sollten Sie diese Nachricht irrt?mlich erhalten haben, ersuchen wir Sie, sofort den Absender dar?ber zu informieren und die Mail zu l?schen.
