In many classes like (org.geotools.filter.v2_0.FES) there are QName definitions with underscores before the local part. Like:
/** @generated */
public static final QName _Filter_Capabilities =
new QName(“http://www.opengis.net/fes/2.0”,“_Filter_Capabilities”);
Is there a real use for this underscore version or is this just a convention to describe unimplemented parts of the schema?
Sampo
Sampo Savolainen
R&D Director, Spatineo Oy
sampo.savolainen@anonymised.com
+358-407555649
Linnankoskenkatu 16 A 17, 00250 Helsinki, Finland
www.spatineo.com, twitter.com/#!/spatineo
www.linkedin.com/company/spatineo-inc
This message may contain privileged and/or confidential information. If you
have received this e-mail in error or are not the intended recipient, you
may not use, copy, disseminate, or distribute it; do not open any
attachments, delete it immediately from your system and notify the sender
promptly by e-mail that you have done so.
Hey Sampo,
It is how the xsd framework allows for bindings to address anonymous types. The WFS and FES schemas unfortunately utilize a lot of anonymous types for elements. This name refers to the anonymous type of the “Filter_Capabilities” element. In the FES class you’ll also find:
public static final QName Filter_Capabilities =
new QName(“http://www.opengis.net/fes/2.0”,“Filter_Capabilities”);
Which refers to the element.
Since the xsd framework utilizes both bindings for elements and types the binding generator uses this convention since sometimes its easier to binding to the type, rather then the element. However in this case I think just an element binding is sufficient but in others it isn’t.
Hope that makes sense.
-Justin
On Fri, Apr 4, 2014 at 2:14 AM, Sampo Savolainen <sampo.savolainen@anonymised.com> wrote:
/** @generated */
Sampo
Sampo Savolainen
+358-407555649
Geoserver-devel mailing list
Geoserver-devel@anonymised.comt
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
