Geoserver docker 2.28.x broken
I dont know if this issue is on the right place:
Since last week the geoserver docker is broken, i’m using docker.osgeo.org/geoserver:2.28.0
log:
3-Nov-2025 11:41:04.083 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
03-Nov-2025 11:41:04.087 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal Context [/geoserver] startup failed due to previous errors
version 2.28.0 is still working, anyone an idea?
I dont see any errors in the docker logs.
You should really be on the GeoServer-Users topic (I can’t work out how to forward a message though),
Anyway, you need to look at the geoserver log file to see what is failing rather than the docker logs.
Ian
you cant read the geoserver logs, because the server wont start, so you cant reach the log files.
So log in and use an editor or pager to view the file on disk.
Ian
I was able to move the topic to the correct category.
In October I worked on docker as part of the code freezes for GeoServer 3. The work I did was to make docker choose tomcat 9 or tomcat 11 base image based on the version of GeoServer being published. The 2.28.0 release was made previously so it should not be affected …
.. so yes if you have more details, perhaps exactly what you used to start up with, it would be good to know what is going on.
For GeoServer 3.x nightly builds testing docker and the install instructions is something to be done.
We also have the new idea of “pending” community modules which will be published alongside GeoServer as they seek wider resources/funding/testing/deployments to be made official extensions.
I just run a clean docker image like this:
docker run -d --name geoserver-test -p 8080:8080 docker.osgeo.org/geoserver:2.28.x
and it ends in an error, tomcat is up and running and this are the logs from docker:
*Welcome to GeoServer 2.28-SNAPSHOT*
*Initialize /opt/geoserver_data/ from data directory included in geoserver.war*
*Starting installation of extensions*
*Finished installation of extensions*
*Installing default server.xml with substituted environment variables*
*NOTE: Picked up JDK_JAVA_OPTIONS:  --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.lang.invoke=ALL-UNNAMED --add-opens=java.base/java.lang.reflect=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.util.concurrent=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED*
*usage: java org.apache.catalina.startup.Catalina \[ -config {pathname} \] \[ -nonaming \] \[ -generateCode \[ {pathname} \] \] \[ -useGeneratedCode \] { -help | start | stop }*
*06-Nov-2025 08:01:21.636 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Server version name:   i_am_a_teapot*
*06-Nov-2025 08:01:21.639 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Server built:*
*06-Nov-2025 08:01:21.639 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Server version number: x.y.z.0*
*06-Nov-2025 08:01:21.639 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log OS Name:               Linux*
*06-Nov-2025 08:01:21.639 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log OS Version:            5.14.0-570.55.1.el9_6.x86_64*
*06-Nov-2025 08:01:21.640 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Architecture:          amd64*
*06-Nov-2025 08:01:21.640 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Java Home:             /opt/java/openjdk*
*06-Nov-2025 08:01:21.640 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log JVM Version:           11.0.28+6*
*06-Nov-2025 08:01:21.640 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor:            Eclipse Adoptium*
*06-Nov-2025 08:01:21.640 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE:         /usr/local/tomcat*
*06-Nov-2025 08:01:21.640 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME:         /usr/local/tomcat*
*06-Nov-2025 08:01:21.655 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang=ALL-UNNAMED*
*06-Nov-2025 08:01:21.657 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang.invoke=ALL-UNNAMED*
*06-Nov-2025 08:01:21.658 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang.reflect=ALL-UNNAMED*
*06-Nov-2025 08:01:21.658 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.io=ALL-UNNAMED*
*06-Nov-2025 08:01:21.658 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util=ALL-UNNAMED*
*06-Nov-2025 08:01:21.658 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util.concurrent=ALL-UNNAMED*
*06-Nov-2025 08:01:21.659 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED*
*06-Nov-2025 08:01:21.659 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/usr/local/tomcat/conf/logging.properties*
*06-Nov-2025 08:01:21.659 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager*
*06-Nov-2025 08:01:21.660 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048*
*06-Nov-2025 08:01:21.660 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources*
*06-Nov-2025 08:01:21.660 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dsun.io.useCanonCaches=false*
*06-Nov-2025 08:01:21.660 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.catalina.security.SecurityListener.UMASK=0027*
*06-Nov-2025 08:01:21.661 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms256m*
*06-Nov-2025 08:01:21.663 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx1g*
*06-Nov-2025 08:01:21.663 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-exports=java.desktop/com.sun.imageio.plugins.jpeg=ALL-UNNAMED*
*06-Nov-2025 08:01:21.663 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-exports=java.desktop/com.sun.imageio.plugins.png=ALL-UNNAMED*
*06-Nov-2025 08:01:21.663 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-exports=java.desktop/sun.awt.image=ALL-UNNAMED*
*06-Nov-2025 08:01:21.663 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang=ALL-UNNAMED*
*06-Nov-2025 08:01:21.663 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util=ALL-UNNAMED*
*06-Nov-2025 08:01:21.664 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang.reflect=ALL-UNNAMED*
*06-Nov-2025 08:01:21.664 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.text=ALL-UNNAMED*
*06-Nov-2025 08:01:21.664 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.desktop/java.awt.font=ALL-UNNAMED*
*06-Nov-2025 08:01:21.664 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.desktop/java.awt.image=ALL-UNNAMED*
*06-Nov-2025 08:01:21.664 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.desktop/javax.imageio.stream=ALL-UNNAMED*
*06-Nov-2025 08:01:21.664 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.desktop/javax.imageio=ALL-UNNAMED*
*06-Nov-2025 08:01:21.665 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.desktop/sun.awt.image=ALL-UNNAMED*
*06-Nov-2025 08:01:21.665 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.naming/com.sun.jndi.ldap=ALL-UNNAMED*
*06-Nov-2025 08:01:21.665 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.desktop/sun.java2d.pipe=ALL-UNNAMED*
*06-Nov-2025 08:01:21.665 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.awt.headless=true*
*06-Nov-2025 08:01:21.666 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dfile.encoding=UTF-8*
*06-Nov-2025 08:01:21.666 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djavax.servlet.request.encoding=UTF-8*
*06-Nov-2025 08:01:21.666 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djavax.servlet.response.encoding=UTF-8*
*06-Nov-2025 08:01:21.667 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -D-XX:SoftRefLRUPolicyMSPerMB=36000*
*06-Nov-2025 08:01:21.667 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xbootclasspath/a:/usr/local/tomcat/lib/marlin.jar*
*06-Nov-2025 08:01:21.667 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dsun.java2d.renderer=sun.java2d.marlin.DMarlinRenderingEngine*
*06-Nov-2025 08:01:21.668 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.geotools.coverage.jaiext.enabled=true*
*06-Nov-2025 08:01:21.668 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dignore.endorsed.dirs=*
*06-Nov-2025 08:01:21.668 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/usr/local/tomcat*
*06-Nov-2025 08:01:21.668 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/usr/local/tomcat*
*06-Nov-2025 08:01:21.668 INFO \[main\] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/usr/local/tomcat/temp*
*06-Nov-2025 08:01:21.702 INFO \[main\] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent Loaded Apache Tomcat Native library \[1.3.1\] using APR version \[1.7.2\].*
*06-Nov-2025 08:01:21.702 INFO \[main\] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR capabilities: IPv6 \[true\], sendfile \[true\], accept filters \[false\], random \[true\], UDS \[true\].*
*06-Nov-2025 08:01:21.703 INFO \[main\] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR/OpenSSL configuration: useAprConnector \[false\], useOpenSSL \[true\]*
*06-Nov-2025 08:01:21.708 INFO \[main\] org.apache.catalina.core.AprLifecycleListener.initializeSSL OpenSSL successfully initialized \[OpenSSL 3.0.13 30 Jan 2024\]*
*06-Nov-2025 08:01:22.084 INFO \[main\] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler \["http-nio-8080"\]*
*06-Nov-2025 08:01:22.120 INFO \[main\] org.apache.catalina.startup.Catalina.load Server initialization in \[874\] milliseconds*
*06-Nov-2025 08:01:22.199 INFO \[main\] org.apache.catalina.core.StandardService.startInternal Starting service \[Catalina\]*
*06-Nov-2025 08:01:22.200 INFO \[main\] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet engine: \[i_am_a_teapot\]*
*06-Nov-2025 08:01:28.816 INFO \[main\] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.*
*06-Nov-2025 08:01:28.840 SEVERE \[main\] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file*
*06-Nov-2025 08:01:28.851 SEVERE \[main\] org.apache.catalina.core.StandardContext.startInternal Context \[/geoserver\] startup failed due to previous errors*
*06-Nov-2025 08:01:29.128 INFO \[main\] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler \["http-nio-8080"\]*
*06-Nov-2025 08:01:29.147 INFO \[main\] org.apache.catalina.startup.Catalina.start Server startup in \[7025\] milliseconds*
and i was able to grep the tomcat logs:
*cat localhost.log
06-Nov-2025 08:01:28.822 INFO \[main\] org.apache.catalina.core.ApplicationContext.log No Spring WebApplicationInitializer types detected on classpath
06-Nov-2025 08:01:28.826 SEVERE \[main\] org.apache.catalina.core.StandardContext.listenerStart Error configuring application listener of class \[org.geoserver.GeoserverInitStartupListener\]
java.lang.UnsupportedClassVersionError: org/geoserver/GeoserverInitStartupListener has been compiled by a more recent version of the Java Runtime (class file version 61.0), this version of the Java Runtime only recognizes class file versions up to 55.0 (unable to load class \[org.geoserver.GeoserverInitStartupListener\])
at org.apache.catalina.loader.WebappClassLoaderBase.findClassInternal(WebappClassLoaderBase.java:2346)
at org.apache.catalina.loader.WebappClassLoaderBase.findClassInternal(WebappClassLoaderBase.java:2212)
at org.apache.catalina.loader.WebappClassLoaderBase.findClass(WebappClassLoaderBase.java:821)
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1312)
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1160)
at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:484)
at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:466)
at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:142)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3974)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4489)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1201)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1191)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:82)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:140)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:747)
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:719)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:209)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:410)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:872)
at org.apache.catalina.startup.Catalina.start(Catalina.java:736)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:342)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:473)
06-Nov-2025 08:01:28.829 SEVERE \[main\] org.apache.catalina.core.StandardContext.listenerStart Error configuring application listener of class \[org.geoserver.logging.LoggingStartupContextListener\]
java.lang.UnsupportedClassVersionError: org/geoserver/logging/LoggingStartupContextListener has been compiled by a more recent version of the Java Runtime (class file version 61.0), this version of the Java Runtime only recognizes class file versions up to 55.0 (unable to load class \[org.geoserver.logging.LoggingStartupContextListener\])
06-Nov-2025 08:01:28.830 SEVERE \[main\] org.apache.catalina.core.StandardContext.listenerStart Error configuring application listener of class \[org.geoserver.platform.GeoServerContextLoaderListener\]
java.lang.UnsupportedClassVersionError: org/geoserver/platform/GeoServerContextLoaderListener has been compiled by a more recent version of the Java Runtime (class file version 61.0), this version of the Java Runtime only recognizes class file versions up to 55.0 (unable to load class \[org.geoserver.platform.GeoServerContextLoaderListener\])
06-Nov-2025 08:01:28.832 SEVERE \[main\] org.apache.catalina.core.StandardContext.listenerStart Error configuring application listener of class \[org.geoserver.platform.GeoServerHttpSessionListenerProxy\]
java.lang.UnsupportedClassVersionError: org/geoserver/platform/GeoServerHttpSessionListenerProxy has been compiled by a more recent version of the Java Runtime (class file version 61.0), this version of the Java Runtime only recognizes class file versions up to 55.0 (unable to load class \[org.geoserver.platform.GeoServerHttpSessionListenerProxy\])
06-Nov-2025 08:01:28.840 SEVERE \[main\] org.apache.catalina.core.StandardContext.listenerStart Skipped installing application listeners due to previous error(s)*
I think I see the problem:
2.28.x is Java 17 minimum now, the release.sh script should be selecting a different base image.
      if [[ "$VERSION" == "3."* ]]; then
         GEOSERVER_BASE_IMAGE=tomcat:11.0-jdk21-temurin-noble
      else
         GEOSERVER_BASE_IMAGE=tomcat:9.0-jdk11-temurin-noble
      fi
We need some logic for:
  • 3.0.x - tomcat 11 jdk17
  • 2.28.x - tomcat 9 jdk17
  • other - tomcat 9 jdk11
Any takers?
I did a simple fix, as JDK17 can be used for active branches of GeoServer.
I note however that many recent docker builds are failing:
+ wget -c -q -O /tmp/geoserver.zip https://build.geoserver.org/geoserver/main/geoserver-main-latest-war.zip
[0me[91m+ unzip geoserver.zip geoserver.war -d /tmp/
[0mArchive:  geoserver.zip
[91merror [geoserver.zip]:  start of central directory not found;
  zipfile corrupt.
  (please check that you have transferred or created the zipfile in the
  appropriate BINARY mode and that you have compiled UnZip properly)
When I go to these URLs directly, it is fine. I expect I am not good at the wget syntax.
Because we build a normal and a gdal image an attempt is made to avoid downloading zip twice.
I have managed to get the docker 2.28.x to build again (clearing the download prior to each run).
It should now use tomcat 9 and JDK 17 and thus start up - Please give it a go and let me know if works!
Yes i downloaded the latest version and it is solved, thank you!
The problem is back in the latest version (from 5th dec), same error, also old java is installed
java --version
openjdk 11.0.28 2025-07-15
OpenJDK Runtime Environment Temurin-11.0.28+6 (build 11.0.28+6)
OpenJDK 64-Bit Server VM Temurin-11.0.28+6 (build 11.0.28+6, mixed mode, sharing)
Some one changed release.sh.
this
  else
  fi
should be:
  else
     GEOSERVER_BASE_IMAGE=tomcat:9.0-jdk17-temurin-noble
  fi
can one of the owner change this!
maybe better to change to:
if [[ “$VERSION” == “3.”* ]]; then
elif [[ “$VERSION” == “2.28.”* ]]; then
else
fi
@jive
Sounds good, yeah I was trying to get it to work during the foss4g community day sprint.
So the action should be to:
The result should now be available, please test and report back!
unfortunately it’s still the wrong version:
docker run -d --name geoserver docker.osgeo.org/geoserver:2.28.x
java --version
Of course I removed old versions first
Maybe you can add the github revision code as label to the container, so you can check which version of geoserver you are running, now i cant see if i’m running the fixed version.
I just tested docker geoserver 3.0.x and does has the same problem, jvm 11 is installed and tomcat 9, instead of tomcat 11.
i think i found the problem:
if [ -n “$VERSION” ] && [ -n “$BUILD” ] && [ -n “$BUILD_GDAL” ] && [ -n “$TAG” ]; then
else
fi
the “ in release.sh should be "
line 26 and 28
can someone change this and build again?
Fixed in Fix string comparison syntax for version checks by petersmythe · Pull Request #258 · geoserver/docker · GitHub and Select the correct jdk based on version (which could be 2.28-SNAPSHOT) by petersmythe · Pull Request #259 · geoserver/docker · GitHub (note @pols, this is open source - you should try to create a PR yourself), building 2.28.x again. It now works for me:
19-Dec-2025 16:51:03.145 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 17.0.16+8
