GeoServer docs ImageMosaic example with COGs not working?
With GeoServer 3.0.2 (and 2.28), I am currently not able to reproduce this ImageMosaic example from the GeoServer docs.
With the test instance below, creating image mosaics from files stored in the GeoServer data dir, or from local GeoTiff or COG files uploaded to GeoServer via its REST API works as expected.
However, so far I had no success in creating mosaics from URLs pointing to remote COG files. Has someone been able to get it to work, or has an idea what could be the issue?
Test Setup
The test setup (on Ubuntu Linux) is started with:
docker compose -f docker-compose.yml up
with docker-compose.yml:
services:
  geoserver:
    image: docker.osgeo.org/geoserver:3.0.2
    ports:
      - "8080:8080"
    environment:
      - INSTALL_EXTENSIONS=true
      - COMMUNITY_EXTENSIONS=cog-http
      - EXTRA_JAVA_OPTS=-Diio.https.aws.region=us-west-2
      - POSTGRES_JNDI_ENABLED=true
      - POSTGRES_HOST=postgis
      - POSTGRES_PORT=5432
      - POSTGRES_DB=geoserver
      - POSTGRES_USERNAME=geoserver
      - POSTGRES_PASSWORD=geoserver
      - POSTGRES_JNDI_RESOURCE_NAME=jdbc/postgresql
    volumes:
      - ./geoserver_data:/opt/geoserver_data/:Z
      - ./additional_libs:/opt/additional_libs:Z # by mounting this we can install libs from host on startup
  postgis:
    image: postgis/postgis:17-3.4-alpine@sha256:5a1dbedac34e0e6663f8b7190d393339571f1cb3ecb2ab2f724524b4f3c7956e
    ports:
      - "5555:5432"
    environment:
      POSTGRES_USER: geoserver
      POSTGRES_PASSWORD: geoserver
    volumes:
      - ./postgis/postgresql_data:/var/lib/postgresql/data:Z
On the host (in the command line), I create the modisvi database in PostGIS:
export PGHOST=localhost
export PGPORT=5432
export PGUSER=geoserver
export PGPASSWORD=geoserver
#export PGDATABASE=geoserver
# NOTE db geoserver already exists and contains postgis extension
psql
# enter commands below in psql prompt
CREATE DATABASE modisvi;
\c modisvi
CREATE EXTENSION postgis;
The *.properties files are created as in the example and zipped with:
zip modisvi.zip *properties
In GeoServer admin web interface, create a workspace test.
To test the database connection, I create a new PostGIS datastore with the above settings in the GeoServer admin interface, and create a new featuretype in the datastore. With psql I confirm that this creates a new table in the configured database.
REST API Call: Init Datastore
The very first REST API call from the example:
curl -u admin:geoserver -XPUT --write-out %{http_code} -H "Content-type:application/zip" --data-binary @modisvi.zip http://localhost:8080/geoserver/rest/workspaces/test/coveragestores/modisvi/file.imagemosaic?configure=none
fails with a 500. GeoServer verbose log output is attached below.
REST API Call: Working Example with Local File
After some experimenting, I found that the above REST API call succeeds if modisvi.zip includes a geotiff file, and the line Cog=true is removed from indexer.properties.
The log output is attached below.
However, this adds a local file to the mosaic, not a URL, which is of course not practical for large COGs.
It also does not seem to store any data in PostGIS, as there is no new table in the configured database. The REST API call stores files from modis.zip below ${GEOSERVER_DATA_DIR}/data/test/modisvi/modisvi/.
REST API Call: Adding URL
Trying to add a URL to the mosaic with:
curl -u admin:geoserver -XPOST -H "Content-type: text/plain" --write-out %{http_code} -d "https://modis-vi-nasa.s3-us-west-2.amazonaws.com/MOD13A1.006/2018.01.01.tif" "http://localhost:8080/geoserver/rest/workspaces/test/coveragestores/modisvi/remote.imagemosaic"
This creates additional files in the data store: modisvi.properties, modisvi.shp, etc.
However, file modisvi.dbf does not contain the added URL, only the local tiff file uploaded in modisvi.zip.
The log for the unsuccessful REST API call is (full stack trace omitted due to post limits):
WARN   [geoserver.rest] - Unrecognized extension: imagemosaic found in request URI
DEBUG  [geoserver.ows] - Could not find a layer group named rest
TRACE  [rest.SuffixAwareHandlerMapping] - Mapped to org.geoserver.rest.catalog.CoverageStoreFileController#coverageStorePut(String, String, UploadMethod, String, String, Boolean, Boolean, String, String, HttpServletRequest)
DEBUG  [org.geoserver] - Thread 76 locking in mode WRITE
DEBUG  [org.geoserver] - Thread 76 got the lock in mode WRITE
DEBUG  [gce.imagemosaic] - Checking file:/usr/local/tomcat/temp/CoverageStoreFileValidator3492394210750434546/
isHidden:false
exists:true
isFiletrue
canRead:true
canWritetrue
canExecute:false
isAbsolute:true
lastModified:1794917601080
length:180
isHidden:false
exists:false
isFilefalse
canRead:false
canWritefalse
canExecute:false
isAbsolute:true
lastModified:0
length:0
DEBUG  [gce.imagemosaic] - Trying to load properties file from URL:file:/usr/local/tomcat/temp/CoverageStoreFileValidator3492394210750434546/indexer.properties
INFO   [gce.imagemosaic] - Required key Levels not found.
DEBUG  [gce.imagemosaic] - Trying to load properties file from URL:file:/usr/local/tomcat/temp/CoverageStoreFileValidator3492394210750434546/timeregex.properties
DEBUG  [gce.imagemosaic] - Trying to load properties file from URL:file:/usr/local/tomcat/temp/CoverageStoreFileValidator3492394210750434546/database.properties
isHidden:false
exists:false
isFilefalse
canRead:false
canWritefalse
canExecute:false
isAbsolute:true
lastModified:0
length:0
isHidden:false
exists:false
isFilefalse
canRead:false
canWritefalse
canExecute:false
isAbsolute:true
lastModified:0
length:0
isHidden:false
exists:true
isFiletrue
canRead:true
canWritetrue
canExecute:false
isAbsolute:true
length:180
isHidden:false
exists:true
isFiletrue
canRead:true
canWritetrue
canExecute:false
isAbsolute:true
lastModified:1794917601081
length:52
isHidden:false
exists:false
isFilefalse
canRead:false
canWritefalse
canExecute:false
isAbsolute:true
lastModified:0
length:0
INFO   [gce.imagemosaic] - Now indexing file indexer.properties
DEBUG  [gce.imagemosaic] - Thread Name http-nio-8080-exec-6
class org.geotools.gce.imagemosaic.ImageMosaicEventHandlers
DEBUG  [gce.imagemosaic] - Done!!!
Done!!!
DEBUG  [gce.imagemosaic] - Indexing complete
isHidden:false
exists:false
isFilefalse
canRead:false
canWritefalse
canExecute:false
isAbsolute:true
lastModified:0
length:0
isHidden:false
exists:false
isFilefalse
canRead:false
canWritefalse
canExecute:false
isAbsolute:true
lastModified:0
length:0
isHidden:false
exists:false
isFilefalse
canRead:false
canWritefalse
canExecute:false
isAbsolute:true
lastModified:0
length:0
isHidden:false
exists:false
isFilefalse
canRead:false
canWritefalse
canExecute:false
isAbsolute:true
lastModified:0
length:0
isHidden:false
exists:true
isFiletrue
canRead:true
canWritetrue
canExecute:false
isAbsolute:true
length:180
isHidden:false
exists:false
isFilefalse
canRead:false
canWritefalse
canExecute:false
isAbsolute:true
lastModified:0
length:0
DEBUG  [gce.imagemosaic] - This plugin accepts File, URL or String. The string may describe a File or an URL
org.geotools.api.data.DataSourceException: This plugin accepts File, URL or String. The string may describe a File or an URL
 at org.geotools.gce.imagemosaic.ImageMosaicReader.<init>(ImageMosaicReader.java:219)
 at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:537)
 at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:101)
 at org.geoserver.rest.catalog.CoverageStoreFileValidator.acceptFile(CoverageStoreFileValidator.java:127)
 at org.geoserver.rest.catalog.CoverageStoreFileValidator.acceptZip(CoverageStoreFileValidator.java:194)
 at org.geoserver.rest.catalog.CoverageStoreFileValidator.accept(CoverageStoreFileValidator.java:88)
 at org.geoserver.rest.util.RESTUtils.handleBinUpload(RESTUtils.java:151)
 at org.geoserver.rest.catalog.AbstractStoreUploadController.handleFileUpload(AbstractStoreUploadController.java:71)
 at org.geoserver.rest.catalog.CoverageStoreFileController.doFileUpload(CoverageStoreFileController.java:450)
 at org.geoserver.rest.catalog.CoverageStoreFileController.coverageStorePut(CoverageStoreFileController.java:142)
 at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103)
Caused by: org.geotools.api.data.DataSourceException: This plugin accepts File, URL or String. The string may describe a File or an URL
 at org.geotools.gce.imagemosaic.ImageMosaicReader.initReaderFromURL(ImageMosaicReader.java:260)
 at org.geotools.gce.imagemosaic.ImageMosaicReader.<init>(ImageMosaicReader.java:217)
 ... 107 more
ERROR  [geoserver.rest] - Error while storing uploaded file:
org.geoserver.rest.RestException 500 INTERNAL_SERVER_ERROR: Error while storing uploaded file:
 at org.geoserver.rest.catalog.AbstractStoreUploadController.handleFileUpload(AbstractStoreUploadController.java:86)
Caused by: java.io.UncheckedIOException: java.io.IOException: Unsupported file format: CoverageStoreFileValidator3492394210750434546, couldn't construct reader for it.
 at org.geoserver.rest.catalog.CoverageStoreFileValidator.accept(CoverageStoreFileValidator.java:93)
 ... 100 more
Caused by: java.io.IOException: Unsupported file format: CoverageStoreFileValidator3492394210750434546, couldn't construct reader for it.
 at org.geoserver.rest.catalog.CoverageStoreFileValidator.acceptFile(CoverageStoreFileValidator.java:135)
 ... 102 more
DEBUG  [org.geoserver] - Thread 76 releasing the lock in mode WRITE
The log for the successful REST API call to create the datastore is:
DEBUG  [org.geoserver] - Thread 79 locking in mode WRITE
DEBUG  [org.geoserver] - Thread 79 got the lock in mode WRITE
DEBUG  [gce.imagemosaic] - Checking file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/
isHidden:false
exists:true
isFiletrue
canRead:true
canWritetrue
canExecute:false
isAbsolute:true
lastModified:1794918948437
length:180
isHidden:false
exists:false
isFilefalse
canRead:false
canWritefalse
canExecute:false
isAbsolute:true
lastModified:0
length:0
DEBUG  [gce.imagemosaic] - Trying to load properties file from URL:file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/indexer.properties
DEBUG  [gce.imagemosaic] - Trying to load properties file from URL:file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/timeregex.properties
DEBUG  [gce.imagemosaic] - Trying to load properties file from URL:file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/database.properties
isHidden:false
exists:false
isFilefalse
canRead:false
canWritefalse
canExecute:false
isAbsolute:true
lastModified:0
length:0
isHidden:false
exists:false
isFilefalse
canRead:false
canWritefalse
canExecute:false
isAbsolute:true
lastModified:0
length:0
isHidden:false
exists:true
isFiletrue
canRead:true
canWritetrue
canExecute:false
isAbsolute:true
length:180
isHidden:false
exists:true
isFiletrue
canRead:true
canWritetrue
canExecute:false
isAbsolute:true
length:52
isHidden:false
exists:false
isFilefalse
canRead:false
canWritefalse
canExecute:false
isAbsolute:true
lastModified:0
length:0
INFO   [gce.imagemosaic] - Now indexing file 2018.01.17.tif
DEBUG  [gce.imagemosaic] - Thread Name http-nio-8080-exec-9
DEBUG  [referencing.factory] - Failure in the primary factory: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "interface org.geotools.api.referencing.IdentifiedObject". Now trying the fallback factory...
DEBUG  [imageio.geotiff] - Logging tiePoints:
Tie point
 Raster Space point (0.0, 0.0, 0.0)
 Model Space point (-179.99999999625516, 80.09371539925912, 0.0)
Logging pixScales:
Pixel Scale
 scaleX=0.005923599592705672 is set? true
 scaleY=0.005923599592705672 is set? true
 scaleZ=0.0 is set? false
geoserver-1  |
geoserver-1  |
DEBUG  [shapefile.files] - Write lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.shp by ShpFiles for deleting all files
DEBUG  [shapefile.dbf] - Field Length for time set to 255 Setting to 8 digits YYYYMMDD
DEBUG  [shapefile.files] - Write lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.shp by StorageFile: modisvi11669749887599359144.shx
DEBUG  [shapefile.files] - Write lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.shx by StorageFile: modisvi11669749887599359144.shx
DEBUG  [shapefile.files] - Write lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.prj by StorageFile: modisvi15008468443977738682.prj
DEBUG  [shapefile.files] - Write lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.shp by StorageFile: modisvi5726977435422952944.shp
DEBUG  [shapefile.files] - Write lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.dbf by StorageFile: modisvi787960638477298165.dbf
DEBUG  [shapefile.files] - Read lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.shp by org.geotools.data.shapefile.shp.ShapefileReader
DEBUG  [shapefile.files] - Read lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.shx by org.geotools.data.shapefile.shp.IndexFile
DEBUG  [shapefile.files] - Read lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.dbf by org.geotools.data.shapefile.dbf.DbaseFileReader
DEBUG  [shapefile.files] - Read lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.prj by org.geotools.data.shapefile.ShapefileSetManager
DEBUG  [imagemosaic.catalog] - BBOXFilterExtractor::extractBasicProperties(): geometryPropertyName is set to 'the_geom'.
DEBUG  [shapefile.files] - Read lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.fix by ShapefileDataStore-modisvi
DEBUG  [shapefile.files] - Read lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.shp by ShapefileDataStore-modisvi
DEBUG  [gce.imagemosaic] - Done with file /usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/2018.01.17.tif
DEBUG  [shapefile.fid] - Generating fids for file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.shp
DEBUG  [shapefile.files] - Read lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.fix by org.geotools.data.shapefile.fid.IndexedFidReader
DEBUG  [shapefile.files] - Write lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.shp by StorageFile: modisvi3411751126067891359.fix
DEBUG  [shapefile.files] - Write lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.fix by StorageFile: modisvi3411751126067891359.fix
DEBUG  [shapefile.files] - Write lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.shp by StorageFile: modisvi15615654385247463770.fix
DEBUG  [shapefile.files] - Write lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.fix by StorageFile: modisvi15615654385247463770.fix
DEBUG  [shapefile.files] - Write lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.dbf by StorageFile: modisvi455139588021590655.dbf
DEBUG  [shapefile.files] - Write lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.shp by StorageFile: modisvi5866714555440319538.shp
DEBUG  [shapefile.files] - Write lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.shx by StorageFile: modisvi679866113124125838.shx
DEBUG  [shapefile.files] - Write lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.qix by org.geotools.data.shapefile.IndexedShapefileFeatureWriter
DEBUG  [shapefile.files] - Read lock: file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.shp by Shapefile Datastore's getBounds Method
INFO   [gce.imagemosaic] - Creating final properties file
Done!!!
isHidden:false
exists:true
isFiletrue
canRead:true
canWritetrue
canExecute:false
isAbsolute:true
lastModified:1794918948518
length:756
isHidden:false
exists:true
isFiletrue
canRead:true
canWritetrue
canExecute:false
isAbsolute:true
lastModified:1794918948515
length:236
DEBUG  [gce.imagemosaic] - Trying to load properties file from URL:file:/usr/local/tomcat/temp/CoverageStoreFileValidator11580275845593282777/modisvi.shp
isHidden:false
exists:false
isFilefalse
canRead:false
canWritefalse
canExecute:false
isAbsolute:true
lastModified:0
length:0
isHidden:false
exists:true
isFiletrue
canRead:true
canWritetrue
canExecute:false
isAbsolute:true
length:180
DEBUG  [gce.imagemosaic] - Checking file:/opt/
isHidden:false
exists:false
isFilefalse
canRead:false
canWritefalse
canExecute:false
isAbsolute:false
lastModified:0
length:0
INFO   [catalog.index] - Unable to access the file for this PropertyCollector: /opt/timeregex.properties
isHidden:false
exists:true
isFiletrue
canRead:true
canWritetrue
canExecute:false
isAbsolute:true
lastModified:1794918948517
length:516
DEBUG  [gce.imagemosaic] - Checking file:/opt/geoserver_data/data/test/modisvi/
isHidden:false
exists:true
isFiletrue
canRead:true
canWritetrue
canExecute:false
isAbsolute:true
lastModified:1794918948537
length:180
INFO   [rest.catalog] - Using existing coverage store: modisvi
TRACE  [geoserver.platform] - Found Property override : 'TRACK_USER' to be unset
TRACE  [geoserver.platform] - Found Java environment variable : 'TRACK_USER' to be unset
TRACE  [geoserver.platform] - Found Servlet context parameter : 'TRACK_USER' to be unset
TRACE  [geoserver.platform] - Found System environment variable : 'TRACK_USER' to be unset
DEBUG  [security.impl] - Filesystem sandbox: null
DEBUG  [geoserver.config] - Persisting coverage store modisvi
DEBUG  [geoserver.config] - Persisted org.geoserver.catalog.impl.CoverageStoreInfoImpl to workspaces/test/modisvi/coveragestore.xml
DEBUG  [geoserver.config] - Persisted jdk.proxy3.$Proxy60 to global.xml
DEBUG  [org.geoserver] - Thread 79 releasing the lock in mode WRITE
