GeoTools / GeoServer PMC meeting - 2025-01-14
Attending
- Torben Barsballe
- Peter Smythe
- Jukka Rahkonnen
- Jody Garnett
- Gabriel Roldan
- Andrea Aime
- Kevin Smith
Actions from prior meetings:
- [DONE] Jody: Request a builds mailing list from OSGeo
Agenda
- happy new year
- GS3 push
- CITE Updates
- Security round up
- PR / Bug round up
Actions
- action: Jody to “2025 blog post” to the user forum? LinkedIn / Facebook / mastodon and highlight GS3 as a priority (please).
- action: Jody to follow up with SAC to see if he can help / hinder
Happy new year
blog post: GeoServer 2025 Roadmap
GS3 push
The gauge shows 80% of funding target - which is great progress.
We need a bit of a push to reach the goal; ideally to start work in Q2.
- Please help promote this activity?
- Could the PSC also pitch in for this activity? We have some prior sponsorship (from cite certification for example?). Consider and make a motion, but it is likely a small amount.
CITE Updates
Update from Andrea:
- During Xmas Break modified tests to run again latest “production” tests required for actual certification).
(this takes over from the geoserver fork from 6 years ago) - Had to make small changes to GeoServer but not much
Adding github workflows for additional tests:
- restored: WMS1.3, WMS 1.1,…
- new: WFS20
- research: Looking at how to certify for output formats GeoTIFF
This is already being a big benefit for the project, super helpful for any changes to the dispatcher (for example recent fixes for WCS version negotiation).
IN PROGRESS:
WMTS 1.0 tests are pretty much working, needs PR to reviewed
(has problems with REST test, but the GUI runs more tests, ticket reported) -
WFS 1.1 workflow is running on old engine, cannot run on the new one due to bug. Andrea reported the problem. Test passes using GUI but not REST API. #109
- The TEAM Engine “team” is working on team engine 6, and is unlikely to fix this soon.
- CITE · GitHub
- to get certified we use the GUI so we will be “okay”, but we like the REST API for blackbox testing
WCS2.0: passing, but also has some problems found with the specifications (namespaces inconsistency between text and schemas - reported as #145)
- expect this to stay “stuck” for a bit while OGC thinks about it
GeoPackage 1.2 should be possible using the same approach as GeoTIFF (testing the output)
Actually getting the certification sticker / reference implementation:
- Peter: OSGeo is willing to host a VM in mid January…
- Making sure you're not a bot!
- Host Docker + GeoServer + PostGIS + enable the different tests
- RnD: We need a script or something to “reset” the database tables after WFS-T transaction
- Discussion about how to run them 1 by one 1 would take some time?
- Idea: Maybe it is worth making a test harness to run the GUI, Selenium for example. Even if we just run them a couple times a year …
Security round up
Peter: Observes people are running older versions, how to help / respond …
- not a surprise, often it takes organization change control policies
- We try and be careful on backwards compatibility
- but it is VERY important, and we cannot support older versions
Sample response:
GeoServer 2.21.4 is not supported presently, can you re-test in a supported version? GeoServer provides fixes for a year as outlined in our security policy, please see recent blog post FAQ.
CSP headers
- Steve asks if that can be on by default?
- Jody says “yes” for 2.27.0 release, with an env variable to disable, and documented in an update page (for backwards compatibility).
When did geoserver stop trusting the geoserver admin?
- Not sure, but we get a lot of bug reports with that assumption ..
- Perhaps if you provide access to “geoserver” but not the “machine” …
- We try and address that in our docs and it can change in the codebase over time
- jody: would like to show “environmental variable” in the GUI when GeoServer admin is “locked out”. See recent example of layer service defaults …
PR / Bug round up
GWC azure job credentials are not working
- gabe provided something, but it is out of budget ..
- gabe can restore when budget / permissions available
WMTS CITE compliance fixes
- gabe reviewed but did not have much to add
- It is about returning the wrong exception
(if you do not have locator, then returning locator = null is not appropriate)
aside:
- release data directory is not doing what I expect when I make a new layer, the default gridsets are from MapML and do not match the other layers (900913 and 4326).
Is this a worth a bug report? Jody to double check with a fresh nightly build and report if needed.
We are getting a number of PRs stacking up:
- we no longer have monthly bug stomps
- time is the most precious resource, please help if available!
