Reminder that the next PMC meeting is scheduled for tomorrow, September 23, at 18:30 CET.
Torben
Torben
Torben Barsballe
Andrea Aime
Jukka Rahkonnen
Peter Smythe
Cécile Vuilleumier
Jody Garnett
David Blasby
Daniele: ImageN CITE test failures
Jody: bin download does not run
Gabe and jody: milestone 2.28-M0
Peter and Jody: website announcement.py automation updates + developer guide
https://osgeo-org.atlassian.net/browse/GEOS-11928
GeoServer 3 code sprint
Markdown
FOSS4Gs
No update, work will proceed
FOSS4G NA: https://www.foss4gna.org/schedule
FOSS4G Auckland: https://2025.foss4g.org/program/schedule (Jody giving 9 presentations and 4 workshops!)
FOSS4G EU 2026: Romania
FOSS4G 2026: Hiroshima
Location confirmed.
Planning accommodations and logistics:
Action:
Check apartment for Cecile
aaime: We need to warn about the code freeze! October 17th - brr!
announcement.py automation + dev guide updates
improved JIRA Disclosure filter
Milestone 2.28-M0
Some gaps to fill
geoserver jars not deployed to osgeo repo for some reason
javadocs were empty, Ian has been working on fixing warnings
todo: but we also need javadocs.yml to fail if there are warnings
check: build with -Prelease
README.html instructions describe Java 11 and 17
Surprise ImageIO-Ext 2.0.0-M0 was a surprise update (due to API change)
https://geoserver.org/announcements/2025/09/20/geoserver-2-28-M0-milestone-released.html
Aside: Java removed finalizers (as a bad idea…)
action:
Release Schedule: https://github.com/geoserver/geoserver/wiki/Release-Schedule
action: 2.28.0 release Andrea, Jody as backup
GEOS-11928 would be helpful, but is not Urgent
Lots of gs-sec-oidc-plugin actions!
web front end, security around that
extract roles the same way as JWT web tokens plugin
keycloak test container ← super helpful!
ImageN
Pen down, most PRs are settled…
Removing rid of as much reflection as possible
Removing JDK 1.2 compatibility
Downstream integration workflow on main branch, version 0.9-SNAPSHOT
No longer update script, …
two scripts: one for pom.xml and one for java code
What is needed for 0.9.0
JAI classes, JAI constants
Q: How does this work with the update script …
not automatic, will need to do some update script work
