Reminder that the next PMC meeting is scheduled for tomorrow, November 4, at 18:30 CET.
Daylight savings has switched over for both CET and PST, so we should still be synced up to the usual time for most people.
Torben
Torben
@groldan you volunteered to make a 2.28.1 release - but honestly 2.28.0 just went out a couple of weeks ago. Have there been enough changes to make a 2.28.1 release useful?
Checking release notes show a handful of fixes, so it is up to you?
The sprint exceeded expectations! Nightly build is running.
Spring updates were a bit of a challenge, required notable rewrites throughout web interfaces
Some challenges with downstream apps:
Next step: Testing! Try out the nightly build binary and report any bugs.
|release| example:
.. parsed-literal::
docker pull docker.osgeo.org/geoserver:|release|.x
Some doc updates have been made to improve installation experience of extensions.
Likewise, the first example of the community module publish profile (OpenSearch) has been added - more to come!
Blog:
Community publish GSIP is “done”:
The “translate” script:
github action so that any commits get built and put them on github pages:
What is next?
Q: Can we actually convert the developers guide? For example …
Q: Can we get this transition during “GS3 Milestone 2”?
Notes about config.py changes:
Release in two weeks time? 2.28.1
Q: Do we need to update release instructions for ImageN?
hmm, I’d say that’s the point of a patch release. This is what we have so far. The community modules changes don’t affect anything but maybe the core fixes do, so my opinion is it’s worth it:
CORE:
Bug fixes:
ad861e7890 [GEOS-11930] OGC-API extension breaks security REST API
1d003ddbd1 [GEOS-11965] KMZ export incorrectly references remote icon URLs instead of embedding them in the KMZ archive (#8904)
9c07be33e3 [GEOS-11963] BlobStorePage breaks when failing to save a blob store configuration
d3c12b5262 [GEOS-11950] : WMS cascade: fully respect ‘restrict to layer bounds’ flag on GetMap requests
666db21fd1 [GEOS-4159] Layer from SQL view feature type details not refreshing after editing sql query (and refreshing attributes there)
Improvements:
32636257fb Bump GeoFence to 3.8.2
e266de3e56 [GEOS-11898] GeoFence: issues in evaluation of virtual layer services access
COMMUNITY:
03d4f95bee [GEOS-11959] New community module GeoWebCache Google Cloud Storage
ae56e6fb75 [GEOS-11890]: Support uploading geoparquet to GeoServer (#8924)
150eaad830 DGGS Follow up on optional resolution on DGGS DataStores (#8919)
d31e1e4ed9 [Legacy] Keep OIDC login button title empty by default (allow runtime overrides) (#8912)
e8052289d8 Keep OIDC login button title empty by default (allow runtime overrides) (#8911)
68ca480e79 [GEOS-11960]: DGGS modules refactoring (#8846) (#8851)
c039ca12b4 [GEOS-11961] OSEO layer management: Support creation of image mosaics in CRS other than 4326
Sounds good, based on one of the geotools discussion we may have enough to make an ImageN 0.9.1 update for your release.
