GeoTools / GeoServer PMC meeting - 2024-10-08
Attending
Torben Barsballe
Dave Blasby
Jody Garnett
Andrea Aime
Peter Smythe
Actions from prior meetings:
[DONE] Torben: Update Jenkins to JDK 17
Agenda
Discourse issues (history and message not sent)
Wicket 9 branch and test case failures (JUNIT 4 vs 5)
Actions
[DONE] Jody: Allow Discourse owners to view users
Jody: Investigate automatic unpinning of topics
Dave: Try and fix some wicket tests
Discourse
Some of us have experienced friction migrating to Discourse
Email notifications have some challenges:
you do not receive your own emails! other than that it should be “okay”
From your profile preferences, use the email tab to adjust email settings.
Important: Select always to avoid missing any topics posted when also logged in to the discourse website!
To test please send an email to introduce yourself (rather than a test message).
Categories: Has an edit button, so you can add, e.g., geoserver
Don’t forget to click “Save Changes”
Sign-up Instructions - Jody has improved them somewhat, see here
No option to see members at the moment, Jody will look into it
Now changed such that Owners and Moderators can see members
Intro/About categories are pinned, but some users are finding they are getting unpinned for no apparent reason… it’s “unpinned” for them and it can be pinned again (clicking on the little pin on the message side).
Thread here on how this works in discourse
There should be a way to disable automatic unpinning.
It looks like this is both a global setting and a per-user setting.
Globally - Un-check ‘automatically unpin topics’ and ‘default topics automatic unpin’ in ‘Settings’ menu(admin authority required). These two settings turn pinned posts into unpinned posts when the user reads it. Further discussion here
For users - in Preferences > Interface, scroll down to other and ensure “Automatically unpin topics when I reach the bottom” is unchecked:
Force tests to run with JUnit 4:
class="github-row" data-github-private-repo="false">
main ← wicket9_run_tests
opened 05:19PM - 08 Oct 24 UTC
All the modules that received a junit-jupiter dependency during the Wicket 9 upg… rade are not running their tests anymore:
community/monitor-kafka/pom.xml: <artifactId>junit-jupiter-api</artifactId>
community/security/keycloak/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/css/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/csw/web-csw/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/geofence/geofence-server/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/geofence/geofence/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/geopkg-output/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/grib/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/gwc-s3/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/importer/web/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/inspire/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/mapml/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/mbstyle/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/metadata/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/netcdf-out/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/netcdf/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/params-extractor/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/rat/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/wcs2_0-eo/web/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/web-resource/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/wmts-multi-dimensional/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/wps-download/pom.xml: <artifactId>junit-jupiter</artifactId>
extension/wps/web-wps/pom.xml: <artifactId>junit-jupiter</artifactId>
rest/pom.xml: <artifactId>junit-jupiter</artifactId>
web/core/pom.xml: <artifactId>junit-jupiter</artifactId>
web/demo/pom.xml: <artifactId>junit-jupiter</artifactId>
web/gwc/pom.xml: <artifactId>junit-jupiter</artifactId>
web/rest/pom.xml: <artifactId>junit-jupiter</artifactId>
web/security/core/pom.xml: <artifactId>junit-jupiter</artifactId>
web/security/jdbc/pom.xml: <artifactId>junit-jupiter</artifactId>
web/security/ldap/pom.xml: <artifactId>junit-jupiter</artifactId>
web/wcs/pom.xml: <artifactId>junit-jupiter</artifactId>
web/wfs/pom.xml: <artifactId>junit-jupiter</artifactId>
web/wms/pom.xml: <artifactId>junit-jupiter</artifactId>
This draft PR tries to fix it, but it also shows many test failures that were not caught during the Wicket 9 upgrade (list collected running the build with -fn so that all modules are built despite test failures)
[ERROR] LayerGroupEditPageTest.testLayerGroupLinkWithWorkspace:299 path: 'publishedinfo:tabs:panel:layers:popup:content:listContainer:items' does not exist for page: LayerGroupEditPage
[ERROR] LayerGroupEditPageTest.testLayerGroupStyle:722 path: 'publishedinfo:tabs:panel:layerGroupStyles:listContainer:styleList:0:layerGroupStylePanel:layerGroupEntryPanel:popup:content:listContainer:items:1:itemProperties:0:component:link' does not exist for page: LayerGroupEditPage
[ERROR] LayerGroupEditPageTest.testLayerGroupStyle2:775 path: 'publishedinfo:tabs:panel:layerGroupStyles:listContainer:styleList:0:layerGroupStylePanel:layerGroupEntryPanel:popup:content:listContainer:items:3:itemProperties:0:component:link' does not exist for page: LayerGroupEditPage
[ERROR] LayerGroupEditPageTest.testLayerGroupStyleSelection:862 path: 'publishedinfo:tabs:panel:layerGroupStyles:listContainer:styleList:0:layerGroupStylePanel:layerGroupEntryPanel:popup:content:listContainer:items:2:itemProperties:0:component:link' does not exist for page: LayerGroupEditPage
[ERROR] LayerGroupEditPageTest.testLayerLink:212 path: 'publishedinfo:tabs:panel:layers:popup:content:listContainer:items' does not exist for page: LayerGroupEditPage
[ERROR] LayerGroupEditPageTest.testLayerLinkWithWorkspace:265 path: 'publishedinfo:tabs:panel:layers:popup:content:listContainer:items' does not exist for page: LayerGroupEditPage
[ERROR] LayerGroupEditPageTest.testStyleGroupLink:238 path: 'publishedinfo:tabs:panel:layers:popup:content:listContainer:items' does not exist for page: LayerGroupEditPage
[ERROR] ResourceConfigurationPageTest.testConsistentUpdateWMTSBbox:834 path: 'publishedinfo:tabs:panel:theList:0:content:referencingForm:nativeSRS:popup:content:table:listContainer:items:1:itemProperties:0:component:link' does not exist for page: ResourceConfigurationPage
[ERROR] ResourceConfigurationPageTest.testWFSDataStoreResource:467 path: 'publishedinfo:tabs:panel:theList:0:content:referencingForm:nativeSRS:popup:content:table:listContainer:items:1:itemProperties:0:component:link' does not exist for page: ResourceConfigurationPage
[ERROR] ResourceConfigurationPageTest.testWMTSOtherCRS:584 path: 'publishedinfo:tabs:panel:theList:0:content:referencingForm:nativeSRS:popup:content:table:listContainer:items:1:itemProperties:0:component:link' does not exist for page: ResourceConfigurationPage
[ERROR] ResourceConfigurationPageTest.testWMTSOtherCRSUrnFormat:622 path: 'publishedinfo:tabs:panel:theList:0:content:referencingForm:nativeSRS:popup:content:table:listContainer:items' does not exist for page: ResourceConfigurationPage
[ERROR] CRSPanelTest.testPlanetaryList:245 Unable to set value. Couldn't find component with name: crs:popup:content:table:filterForm:filter ==> expected: not <null>
[ERROR] CRSPanelTest.testPlanetaryPopupWindow:227 path: 'form:crs:popup:content:wkt' does not exist for page: CRSPanelTestPage
[ERROR] CRSPanelTest.testPopupWindow:69 path: 'form:crs:popup:content:wkt' does not exist for page: CRSPanelTestPage
[ERROR] GeoServerAboutPageTest.testHideSensitiveInfo:40 » WicketRuntime The component(...
[ERROR] GeoServerAboutPageTest.testLoginFormAction:21 » WicketRuntime The component(s)...
[ERROR] PageResourceBrowserTest.testCopyPaste:166 path: 'dialog:dialog:content:form:userPanel' does not exist for page: PageResourceBrowser
[ERROR] PageResourceBrowserTest.testCutPaste:107 path: 'dialog:dialog:content:form:userPanel' does not exist for page: PageResourceBrowser
[ERROR] PageResourceBrowserTest.testDelete:228 path: 'dialog:dialog:content:form:userPanel' does not exist for page: PageResourceBrowser
[ERROR] PageResourceBrowserTest.testEdit:392 path: 'dialog:dialog:content:form:userPanel' does not exist for page: PageResourceBrowser
[ERROR] PageResourceBrowserTest.testNew:353 path: 'dialog:dialog:content:form:userPanel' does not exist for page: PageResourceBrowser
[ERROR] PageResourceBrowserTest.testRename:251 path: 'dialog:dialog:content:form:userPanel' does not exist for page: PageResourceBrowser
[ERROR] PageResourceBrowserTest.testUpload:315 path: 'dialog:dialog:content:form:userPanel' does not exist for page: PageResourceBrowser
[ERROR] XMLRoleConfigDetailsPanelTest.testAddModifyRemove:129->setFileName:66 Unable to set value. Couldn't find component with name: panel:content:fileName ==> expected: not <null>
[ERROR] URLChecksPageTest.testDeleteRule:103 path: 'dialog:dialog:content:form:submit' does not exist for page: URLChecksPage
[ERROR] XMLUserGroupConfigDetailsPanelTest.testAddModify:130->setFileName:77 Unable to set value. Couldn't find component with name: panel:content:fileName ==> expected: not <null>
[ERROR] EditUserPageTest.testFill:39->doTestFill:79->AbstractUserPageTest.assignRole:77 » NullPointer
[ERROR] EditUserPageTest.testReadOnlyUserGroupService:116->doTestReadOnlyUserGroupService:141->AbstractUserPageTest.assignRole:77 » NullPointer
[ERROR] NewUserPageTest.testFill:50->doTestFill:75->AbstractUserPageTest.assignRole:77 » NullPointer
[ERROR] NewUserPageTest.testFill2:158->doTestFill2:177->AbstractUserPageTest.assignGroup:86 » NullPointer
[ERROR] NewUserPageTest.testFill3:111->doTestFill3:129->AbstractUserPageTest.assignRole:77 » NullPointer
[ERROR] JDBCEditUserPageTest.testFill:23->EditUserPageTest.doTestFill:79->AbstractUserPageTest.assignRole:77 » NullPointer
[ERROR] JDBCEditUserPageTest.testReadOnlyUserGroupService:29->EditUserPageTest.doTestReadOnlyUserGroupService:141->AbstractUserPageTest.assignRole:77 » NullPointer
[ERROR] JDBCNewUserPageTest.testFill:23->NewUserPageTest.doTestFill:75->AbstractUserPageTest.assignRole:77 » NullPointer
[ERROR] JDBCNewUserPageTest.testFill2:35->NewUserPageTest.doTestFill2:177->AbstractUserPageTest.assignGroup:86 » NullPointer
[ERROR] JDBCNewUserPageTest.testFill3:29->NewUserPageTest.doTestFill3:129->AbstractUserPageTest.assignRole:77 » NullPointer
[ERROR] BulkOperationsPageTest.testClearAll:84 path: 'dialog:dialog:content:form:userPanel' does not exist for page: MetadataBulkOperationsPage
[ERROR] BulkOperationsPageTest.testFixAll:45 path: 'dialog:dialog:content:form:userPanel' does not exist for page: MetadataBulkOperationsPage
[ERROR] BulkOperationsPageTest.testImport:60 path: 'dialog:dialog:content:form:userPanel' does not exist for page: MetadataBulkOperationsPage
[ERROR] BulkOperationsPageTest.testNativeToCustom:75 path: 'dialog:dialog:content:form:userPanel' does not exist for page: MetadataBulkOperationsPage
[ERROR] LayerMetadataTabTest.testGenerateFeatureCatalogueAndDomain:717 path: 'publishedinfo:tabs:panel:metadataPanel:attributesPanel:attributesTablePanel:listContainer:items:13:itemProperties:1:component:attributesTablePanel:listContainer:items:2:itemProperties:1:component:dialog:dialog:content:form:submit' does not exist for page: ResourceConfigurationPage
[ERROR] LayerMetadataTabTest.testImportFromGeonetwork:650 path: 'publishedinfo:tabs:panel:geonetworkPanel:importDialog:dialog:content:form:submit' does not exist for page: ResourceConfigurationPage
[ERROR] LayerMetadataTabTest.testLinkAndUnlinkDeleteRowTemplatesBug:479 path: 'publishedinfo:tabs:panel:importTemplatePanel:importDialog:dialog:content:form:submit' does not exist for page: ResourceConfigurationPage
[ERROR] LayerMetadataTabTest.testLinkRowTemplatesBug:581 path: 'publishedinfo:tabs:panel:importTemplatePanel:importDialog:dialog:content:form:submit' does not exist for page: ResourceConfigurationPage
[ERROR] LayerMetadataTabTest.testLinkWithSimpleAndListTemplates:301 path: 'publishedinfo:tabs:panel:importTemplatePanel:importDialog:dialog:content:form:submit' does not exist for page: ResourceConfigurationPage
[ERROR] LayerMetadataTabTest.testTemplatesRemainInPriorityOrder:604 path: 'publishedinfo:tabs:panel:importTemplatePanel:importDialog:dialog:content:form:submit' does not exist for page: ResourceConfigurationPage
[ERROR] LayerMetadataTabTest.testUnlinkFromSimpleAndListTemplates:405 path: 'publishedinfo:tabs:panel:importTemplatePanel:importDialog:dialog:content:form:submit' does not exist for page: ResourceConfigurationPage
[ERROR] TemplatesPageTest.testDelete:145 path: 'dialog:dialog:content:form:userPanel' does not exist for page: MetadataTemplatesPage
[ERROR] MapPreviewPageTest.testMaxNumberOfFeaturesForPreview:141->assertMaxFeaturesInData:189
[ERROR] MapPreviewPageTest.testNameURLEncoding:279
[ERROR] StyleEditPageTest.testInsertImage:267 path: 'dialog:dialog:content:form:userPanel' does not exist for page: StyleEditPage
[ERROR] StyleEditPageTest.testInsertImageSLD11:366 path: 'dialog:dialog:content:form:userPanel' does not exist for page: StyleEditPage
[ERROR] StyleEditPageTest.testLayerAttributesTabWMS:459 path: 'styleForm:popup:content:layer.table' does not exist for page: StyleEditPage
[ERROR] StyleEditPageTest.testLayerAttributesUnreachableLayer:443 path: 'styleForm:popup:content:layer.table' does not exist for page: StyleEditPage
[ERROR] StyleNewPageTest.testInsertImage:493 path: 'dialog:dialog:content:form:userPanel' does not exist for page: StyleNewPage
[ERROR] StyleNewPageTest.testInsertImageEscaped:564 path: 'dialog:dialog:content:form' does not exist for page: StyleNewPage
[ERROR] StyleNewPageTest.testLegendChooseImage:600 path: 'dialog:dialog:content:form:userPanel' does not exist for page: StyleNewPage
[ERROR] ProcessStatusPageTest.test:98 path: 'dialog:dialog:content:form:submit' does not exist for page: ProcessStatusPage
[ERROR] ImportTaskTableTest.testTwoCRSSetByFindThenApply:66 path: 'taskTable:listContainer:items:1:itemProperties:2:component:form:crs:popup:content:table:listContainer:items:1:itemProperties:0:component:link' does not exist for page: StartComponentInPage
[ERROR] CachedLayersPageTest.testGWCClean:223 path: 'dialog:dialog:content:form:submit' does not exist for page: CachedLayersPage
# Checklist
- [ ] I have read the [contribution guidelines](https://github.com/geoserver/geoserver/blob/main/CONTRIBUTING.md).
- [ ] I have sent a [Contribution Licence Agreement](https://docs.geoserver.org/latest/en/developer/policies/committing.html) (not required for small changes, e.g., fixing typos in documentation).
- [ ] First PR targets the `main` branch (backports managed later; ignore for branch specific issues).
- [ ] All the build checks are green ([see automated QA checks](https://docs.geoserver.org/latest/en/developer/qa-guide/index.html)).
For core and extension modules:
- [ ] New unit tests have been added covering the changes.
- [ ] [Documentation](https://github.com/geoserver/geoserver/tree/main/doc/en/user/source) has been updated (if change is visible to end users).
- [ ] The [REST API docs](https://github.com/geoserver/geoserver/tree/main/doc/en/api/1.0.0) have been updated (when changing configuration objects or the REST controllers).
- [ ] There is an issue in the [GeoServer Jira](https://osgeo-org.atlassian.net/browse/GEOS/summary) (except for changes that do not affect administrators or end users in any way).
- [ ] Commit message(s) must be in the form ``[GEOS-XYZWV] Title of the Jira ticket``.
- [ ] Bug fixes and small new features are presented as a single commit.
- [ ] Each commit has a single objective (if there are multiple commits, each has a separate JIRA ticket describing its goal).
Print the containment hierarchy for a wicket test, while it’s running:
print(tester.getLastRenderedPage(), true, true);
It appears these failures are caused by actual structural changes to the wicket DOM introduced by the wicket upgrade.
The fix should be relatively straightforward, but still requires some effort to complete
Dave can take a look at the PR and try and fix some of these.
Also look for:
[INFO] Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
