[Geoserver-users] 1. Re: NamedLayer / FeatureTypeName - Problem in SLD with GeoServer
Dear Frederick,
I had the same problem at exactly the same time, and was eagerly looking for
the answers. I did not get them in my digests either :(. Could you please
send around a summary of the solution?
Martin
On 25/05/11 6:26 PM, "geoserver-users-request@lists.sourceforge.net"
Martin Tomko, PhD.
Senior Project Manager, Information Infrastructure Design, AURIN
Level 5, Architecture Building
University of Melbourne VIC 3010
AUSTRALIA
T: +61 3 9035 3298
E: tomkom@anonymised.com <mailto:tomkom@anonymised.com>
W: www.aurin.org.au <www.aurin.org.au>
Hey, no problem:
I don’t know if it is essential to have the same layerorder in the layergroup as in the SLD-file but in my case, in which it’s working, it is.
  1. add the contents of the SLD file as a new style in GeoServer
  2. assign that style to every layer in the layergroup
  3. when you send the wms-request make sure to add the sld=… parameter in the request url (http://192.1…/geoserver/wms?sld=yoursld.sld&style=&request=GetMap… (make sure to leave the value of the style parameter empty since this works only in combination with a splitted layer parameter)
You don’t need to upload your sld file to any other location to use the url in the sld prameter. Once you created a new style in geoserver the SLD-file can be found in http://192.1…/geoserveer/styles/yourstyle.sld
This is how it worked in my case, I hope this helps…
Frederick Löbig
Röderichstraße 59
60489 Frankfurt am Main
E:: Frederick.Loebig@anonymised.com
P: +49 (0) 69 - 78 99 52 41
M: +49 (0) 174 - 70 89 296
Office:
euNetworks GmbH
Ludwig-Landmann-Straße 405
60486 Frankfurt am Main
P: +49 (0) 69 - 90 554 - 532
E: Frederick.Loebig@anonymised.com
S: floebig
This email and any attachments may contain confidential and/or legally privileged information. If you are not the intended recipient, please delete the email without reading it and notify the sender.
Date: Thu, 26 May 2011 09:17:23 +1000
Subject: 1. Re: NamedLayer / FeatureTypeName - Problem in SLD with GeoServer
To: geoserver-users@anonymised.comurceforge.net
CC: fl@anonymised.com
Dear Frederick,
Martin
On 25/05/11 6:26 PM, “geoserver-users-request@lists.sourceforge.net
Martin Tomko, PhD.
AUSTRALIA
T: +61 3 9035 3298
E: tomkom@anonymised.commailto:tomkom@anonymised.com
Thank Frederick, that’s a wonderful writeup.
Will see if that works for us.
Martin
On 26/05/11 5:49 PM, “Frederick Löbig” fl@anonymised.com wrote:
Hey, no problem:
  3. when you send the wms-request make sure to add the sld=… parameter in the request url (http://192.1…/geoserver/wms?sld=yoursld.sld&style=&request=GetMap…. (make sure to leave the value of the style parameter empty since this works only in combination with a splitted layer parameter)
Frederick Löbig
Röderichstraße 59
Office:
euNetworks GmbH
S: floebig
Dear Frederick,
Martin
Martin Tomko, PhD.
AUSTRALIA
T: +61 3 9035 3298
Martin Tomko, PhD.
AUSTRALIA
T: +61 3 9035 3298
E: tomkom@anonymised.com.4051… <mailto:tomkom@anonymised.com>
