[Geoserver-users] 2.1-RC3 GeoWebCache fails to generate png tiles
Using the GeoWebCache Demos page from the Web admin interface connected to a vanilla GeoServer2.1-RC3 (no user data), the OpenLayers links fail to produce any png tiles (appear as mini "?" icons on white background, grey outline). Links for jpeg seem to work fine. Nothing obvious in the log file to indicate a problem.
Versions 2.0.2 and 2.1-RC1 appear to work as expected.
Running on OSX 10.6.6, Java 1.6.0.
Is this a known issue?
Rick
I’m seeing the same thing.
Roger
On Wed, Mar 30, 2011 at 4:27 PM, Rick Workman <ridgeworks@anonymised.com> wrote:
Using the GeoWebCache Demos page from the Web admin interface connected to a vanilla GeoServer2.1-RC3 (no user data), the OpenLayers links fail to produce any png tiles (appear as mini “?” icons on white background, grey outline). Links for jpeg seem to work fine. Nothing obvious in the log file to indicate a problem.
Rick
Create and publish websites with WebMatrix
Use the most popular FREE web apps or write code yourself;
WebMatrix provides all the features you need to develop and
publish your website. http://p.sf.net/sfu/ms-webmatrix-sf
Geoserver-users mailing list
On Wed, 2011-03-30 at 18:50 +0200, Roger Bedell wrote:
I'm seeing the same thing.
Roger
        a problem.
that's because for some reason the png encoder didn't work with 3-band
images but generated broken png files without complaining.
Sorry that bug slipped in for the RC. It's already fixed and the fix
will be on the next RC.
Meanwhile feel free to try out a recent nightly build.
Gabriel
        Rick
Gabriel Roldan
groldan@anonymised.com
Expert service straight from the developers
Thanks Gabriel. I’ve loaded the latest nightly, and can confirm that this has been fixed.
Roger
On Wed, Mar 30, 2011 at 9:37 PM, Gabriel Roldán <groldan@anonymised.com> wrote:
Roger
a problem.
that’s because for some reason the png encoder didn’t work with 3-band
Sorry that bug slipped in for the RC. It’s already fixed and the fix
Gabriel
Rick
Gabriel Roldan
