[Geoserver-users] 2.6 pink tiles
From which version did you update? Tell also a bit more about the environment: Linux/Windows, 32 or 64 bit, java version, with or without native JAI and which file format in tiles?
Pink tiles mean no tile at all in that place and the reason may be timeout in seeding process or some other failure. If you create png tiles on Windows it can be for example related to http://thread.gmane.org/gmane.comp.gis.geoserver.user/43732
About seeding/reseeding having no effect, how did you test that? The OpenLayers map that opens from the layer preview does not read tiles from the cache even if the cache is seeded because the WMS GetMaps which this app is sending do not match with extents of tiles in the cache. Therefore seeding does not remove pink tiles from layer preview. The other viewer that opens through http://localhost:8080/geoserver/gwc/demo/ does hit the cache and after successful seeding it should not show pink tiles. At least this is how I understand the situation.
-Jukka Rahkonen-
Ismail, Mark wrote:
Hi
I upgraded to 2.6 today and am having some problems with my base maps
They are loading much slower and I am getting quite a few pink tiles
Assuming it was something to do with the geowebcache I have wiped it and am trying to regenerate the tiles
The tasks are starting then when you click refresh they disappear and a few files are appearing in the cache but it is not completing
I have tried seed and reseed with no luck
Any tips / tricks to get it working in 2.6 ?
Mark Ismail
Principal IT Officer
Tel: 0151 443 3021
Knowsley Council ê Westmorland Road ê Huyton ê L36 9GL
Save time – use the IT Service Desk Self Serve Application
This e-mail and any attachments are confidential. It may contain privileged information and is intended for the named recipient(s) only. It must not be distributed without consent. If you are not one of the intended recipients, please notify the sender immediately and do not disclose, distribute, or retain this email or any part of it and do not take any action based on it.
Unless expressly stated, opinions in this email are those of the individual sender, and not of Knowsley MBC. Legally binding obligations can only be created for, or be entered into on behalf of, Knowsley MBC by duly authorised officers or representatives.
Knowsley MBC excludes any liability whatsoever for any offence caused, any direct or consequential loss arising from the use, or reliance on, this e-mail or its contents. We believe but do not warrant that this e-mail and any attachments are virus free. You must therefore take full responsibility for virus checking and no responsibility is accepted for loss or damage arising from viruses or changes made to this message after it was sent. Knowsley MBC reserves the right to monitor and/or record all e-mail communications through its network in accordance with relevant legislation.
Hi
I updated from version 2.5.2 on windows server 2008 64bit which was using apache tomcat 8.09 and jre-8u11-windows-i586
I upgraded apache to 8.14 and the jre to jre-8u20-windows-i586 to fix a security vulnerability
I am using native jai and the tiles are in png8
While I had to rebuild apache I decided to upgrade geoserver at the same time
I have my data folder on the local c drive – the server is a Vmware server. The data folder included a 21gb cache of my 5 ordnance survey base maps as layer groups
I decided that reseed wasn’t working by emptying one the of layers using tile caching / tile layers empty option and then reseeding.
I opened the cache folder where there were no tiles and hit reseed
The reseed form opened with 300k ish tiles to do and said it had done a few hundred – by checking the folder I could see the files there
When you hit refresh on the seed form to update progress the job disappears, the cache folder still only has a few files in it
I tried this on a few layers with exactly the same result.
I spent some time this morning monitoring the network traffic and managed to find an error :-
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
Internal error
Error occurred getting table name list.
ORA-01000: maximum open cursors exceeded
All my data is stored in oracle – I am using the new 2.6 oracle jar file
I right clicked and did show picture a few times on the missing pink tile that generated the above error and it appeared
http://geolive.knowsley.gov.uk:8080/geoserver/Geostore/wms?LAYERS=OS%20Master&FORMAT=image%2Fpng8&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A27700&BBOX=346585.83789474,391167.5004644,347294.07541796,391875.73798762&WIDTH=256&HEIGHT=256
it would seem to be an issue with the oracle connection to my data
Mark Ismail
Tel: 0151 443 3021
From: Rahkonen Jukka (Tike) [mailto:jukka.rahkonen@anonymised.com.]
Sent: 09 October 2014 08:10
To: Ismail, Mark; geoserver mailing list (geoserver-users@anonymised.comceforge.net)
Subject: Re: 2.6 pink tiles
-Jukka Rahkonen-
Ismail, Mark wrote:
Hi
Mark Ismail
Tel: 0151 443 3021
On Thu, Oct 9, 2014 at 10:42 AM, Ismail, Mark <mark.ismail@anonymised.com>
wrote:
Hi
Hmm... Java 8 is not tested with GeoServer.
time
to find an error :-
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
ServiceExceptionReport SYSTEM "
http://geolive.knowsley.gov.uk:8080/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd&quot;&gt;
<ServiceExceptionReport version="1.1.1" > <ServiceException>
      Internal error
</ServiceException></ServiceExceptionReport>
Ah, this is a well known problem with Oracle, not much we can do on our
side, Oracle prepared statements keep
cursors open, prepared statements are associated to connections,
we keep connections open in the pool because opening a new one with Oracle
is _very_ expensive
(there is a long thread on this topic, maybe one or two year ago, in this
mailing list).
What you can do to limit the issue is to either tune your Oracle
installation to allow more cursors to be opened,
or go in the GeoServer store configuration and reduce the number of
prepared statements kept open per
connection (the default if 50), eventually also reduce the number of
connections in the pool
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I have fixed the pink tile issue by replacing ojdbc7.jar with ojdbc6.jar and changing to jre7
Which is the one I was using with 2.5.2
The issue now is the seeding / wms loading is very slow (approx 30% of normal loading speed)
I uninstalled 2.6.0 and went back to 2.5.2 and speeds are back to normal
Mark Ismail
Tel: 0151 443 3021
From: andrea.aime@…84… [mailto:andrea.aime@…84…] On Behalf Of Andrea Aime
Sent: 09 October 2014 10:00
To: Ismail, Mark
Cc: Rahkonen Jukka (Tike); geoserver mailing, list (geoserver-users@lists.sourceforge.net)
Subject: Re: [Geoserver-users] 2.6 pink tiles
On Thu, Oct 9, 2014 at 10:42 AM, Ismail, Mark <mark.ismail@…6440…> wrote:
Hi
Hmm… Java 8 is not tested with GeoServer.
Internal error
Ah, this is a well known problem with Oracle, not much we can do on our side, Oracle prepared statements keep
we keep connections open in the pool because opening a new one with Oracle is very expensive
(there is a long thread on this topic, maybe one or two year ago, in this mailing list).
What you can do to limit the issue is to either tune your Oracle installation to allow more cursors to be opened,
or go in the GeoServer store configuration and reduce the number of prepared statements kept open per
connection (the default if 50), eventually also reduce the number of connections in the pool
Ing. Andrea Aime
@geowolf
Technical Lead
I am using openlayers 2 and issuing a WMSGetFeatureInfo request to geoserver
It works fine but It is far to sensitive to where you click – if you don’t get right in the centre of a point or icon it finds nothing, it can take 2 or 3 attempts to get a response even if clicking carefully and zoomed in
Is there any way to make that click “less sensitive” so it will pick up the closest point to the mouse click ?
I know this isn’t strictly a geoserver issue but I’ve found nothing useful on the openlayers forums
Mark Ismail
Tel: 0151 443 3021
Mark Ismail
Tel: 0151 443 3021
Mark,
You might take a look at the clickTolerance setting as described at the link below:
http://dev.openlayers.org/releases/OpenLayers-2.13.1/doc/apidocs/files/OpenLayers/Control/GetFeature-js.html#OpenLayers.Control.GetFeature.clickTolerance
Hope this helps.
Jerome Wendell
From: Ismail, Mark [mailto:mark.ismail@anonymised.com]
Sent: Thursday, October 09, 2014 9:06 AM
To: geoserver mailing, list (geoserver-users@anonymised.come.net)
Subject: [Geoserver-users] openlayers WMSGetFeatureInfo and geoserver too sensitive
Mark Ismail
Tel: 0151 443 3021
Hi
Thanks for the replies
Ive tried
vendorParams: { buffer:100 },
tolerance: 100,
in the openlayers wmsgetfeatureinfo request but no change, the points are still very difficult to click even with these extreme settings
From the open layers docs tolerance doesn’t seem to be a supported parameter anymore though
Mark Ismail
Tel: 0151 443 3021
Sent: 09 October 2014 14:32
To: Ismail, Mark; ‘geoserver mailing, list’
Subject: RE: [Geoserver-users] openlayers WMSGetFeatureInfo and geoserver too sensitive
Mark,
Hope this helps.
Jerome Wendell
To: geoserver mailing, list (geoserver-users@lists.sourceforge.net)
Mark Ismail
Tel: 0151 443 3021
This is my code;
  control = new OpenLayers.Control.GetFeature({
                protocol: OpenLayers.Protocol.WFS.fromWMSLayer(theLayer),
                box: false,
                hover: false,
                maxFeatures: 20,
                multipleKey: "shiftKey",
                toggleKey: "ctrlKey",
                clickTolerance:30
  control.events.register("featureselected", this, function(e) { selected.addFeatures([e.feature]); displayInfo(e); });
  control.events.register("featureunselected", this, function(e) { selected.removeFeatures([e.feature]); });
  control.events.register("hoverfeature", this, function(e) { hover.addFeatures([e.feature]); displayInfo(e); });
  control.events.register("outfeature", this, function(e) { hover.removeFeatures([e.feature]); });
  map.addControl(control);
  control.activate();
Note the clickTolerance line
Russ
On 9 Oct 2014, at 16:02, Ismail, Mark <mark.ismail@anonymised.com> wrote:
Hi
Ive tried
tolerance: 100,
Mark Ismail
Tel: 0151 443 3021
From: Jerome A. Wendell [mailto:jawendell@anonymised.com]
To: Ismail, Mark; 'geoserver mailing, list'
Mark,
Hope this helps.
Jerome Wendell
Mark Ismail
Tel: 0151 443 3021
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk_______________________________________________
Geoserver-users mailing list
Check with Firebug which kind of requests your application is really sending to Geoserver. It looks like it can use WFS and GetFeature but until now I have believed it is WMS and GetFeatureInfo. Actually you would probably get better answers from OpenLayers list.
-Jukka Rahkonen-
Russell Hore wrote:
This is my code;
                box: false,
                hover: false,
                maxFeatures: 20,
                clickTolerance:30
control.activate();
Russ
On 9 Oct 2014, at 16:02, Ismail, Mark <mark.ismail@anonymised.com<mailto:mark.ismail@anonymised.com>> wrote:
Hi
Ive tried
tolerance: 100,
Mark Ismail
Tel: 0151 443 3021
Knowsley Council • Westmorland Road • Huyton • L36 9GL
Save time – use the IT Service Desk Self Serve<http://kmbcselfservice/&gt; Application
Mark,
Hope this helps.
Jerome Wendell
To: geoserver mailing, list (geoserver-users@lists.sourceforge.net<mailto:geoserver-users@lists.sourceforge.net>)
Mark Ismail
Tel: 0151 443 3021
Geoserver-users@lists.sourceforge.net<mailto:Geoserver-users@anonymised.comrge.net>
I found out what was making my clicks overly sensitive
I had changed some of my layers from
to
http://geolive.knowsley.gov.uk:8080/geoserver/Geostore/wms?buffer=8
to stop icons being clipped like this :-
When I removed the ?buffer=8 the WMSGetFeatureInfo clicks now work normally
But now I need an alternative way to stop the icons clipping
Mark Ismail
Tel: 0151 443 3021
Mark,
Hope this helps.
Jerome Wendell
Mark Ismail
Tel: 0151 443 3021
On Mon, Oct 13, 2014 at 1:29 PM, Ismail, Mark <mark.ismail@anonymised.com>
to
normally
Are the icons dynamically sized, based on a attribute value?
About the clipping, there is probably going to be a fix in the next 2.5.3
release, to be sure,
try out a nightly build here:
http://ares.boundlessgeo.com/geoserver/2.5.x/
(those are going to be released with further minimal or no changes as
2.5.3, so don't be
scared by the "nightly" term)
Ing. Andrea Aime
@geowolf
Technical Lead
Hi
The icons are fixed size 12 point
I am trying to get a test server set up – if I do I will test a nightly
Mark Ismail
Tel: 0151 443 3021
Sent: 13 October 2014 12:49
To: Ismail, Mark
Cc: geoserver mailing, list
Subject: Re: [Geoserver-users] openlayers WMSGetFeatureInfo and geoserver too sensitive
to
About the clipping, there is probably going to be a fix in the next 2.5.3 release, to be sure,
(those are going to be released with further minimal or no changes as 2.5.3, so don’t be
scared by the “nightly” term)
Ing. Andrea Aime
@geowolf
Technical Lead
