[Geoserver-users] 404 not found for http://localhost:8080/geoserver/web
I have just installed geoserver with QGIS 2.6.1 on Windows 8.1 64 and I
cannot seem to connect to http://localhost:8080/geoserver/web. I have
attached a log. Thanks geoserver.log
<http://osgeo-org.1560.x6.nabble.com/file/n5191023/geoserver.log&gt;
View this message in context: http://osgeo-org.1560.x6.nabble.com/404-not-found-for-http-localhost-8080-geoserver-web-tp5191023.html
the startup logs look fine. What do you mean by “cannot connnect to http://localhost:8080/geoserver/web”?
You mention QGis, but the address you are referring to can only be used with a web browser?
On Mon, Mar 2, 2015 at 9:54 PM, kdric <killiandriscoll@anonymised.com> wrote:
<http://osgeo-org.1560.x6.nabble.com/file/n5191023/geoserver.log>
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks - if I try and add a new catalog with QGIS in order to publish a map I
get this warning "Warning: Could not connect to the catalog at that URL":
the url is set to be http://localhost:8080/geoserver/web
View this message in context: http://osgeo-org.1560.x6.nabble.com/404-not-found-for-http-localhost-8080-geoserver-web-tp5191023p5191029.html
Also, following the user guide it says "The web admin tool is accessed via a
web browser at http://<host>:<port>/geoserver (for a default installation on
the local host the link is http://localhost:8080/geoserver/web )." But I get
the 404 for that URL.
View this message in context: http://osgeo-org.1560.x6.nabble.com/404-not-found-for-http-localhost-8080-geoserver-web-tp5191023p5191031.html
On Mon, Mar 2, 2015 at 10:25 PM, kdric <killiandriscoll@anonymised.com> wrote:
map I
I believe you are using the OpenGeo Suite and its qgis GeoServer plugin
then?
In that case you should ask Boundless for support, here we can only help
for a standard
GeoServer, there is nothing we can do for the extra functionality provided
in that product.
GeoSolutions for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks - for the standard geoserver the guide says "The web admin tool is
accessed via a web browser at http://<host>:<port>/geoserver (for a default
installation on the local host the link is
http://localhost:8080/geoserver/web )." But I get the 404 for that URL. Can
you help with that?
View this message in context: http://osgeo-org.1560.x6.nabble.com/404-not-found-for-http-localhost-8080-geoserver-web-tp5191023p5191038.html
On Mon, Mar 2, 2015 at 10:38 PM, kdric <killiandriscoll@anonymised.com> wrote:
default
Can
you help with that?
Only if you have a standard GeoServer downloaded from geoserver.org, the
suite is a product, not a open source project (e.g., different kind of
beast)
That said... the startup logs seem to imply everything started up find, not
sure why you cannot login.
Maybe port 8080 is already used by some other program? Skype sometimes uses
it, Oracle XE does that too, there are
probably other programs using that port as well.
Ing. Andrea Aime
@geowolf
Technical Lead
Yes, I downloaded from geoserver.org,
View this message in context: http://osgeo-org.1560.x6.nabble.com/404-not-found-for-http-localhost-8080-geoserver-web-tp5191023p5191044.html
I took a look at the lsit of ports in the firewall and the only one listed
for 8080 is an inbound tcp for geoserver; is that configuration correct?
View this message in context: http://osgeo-org.1560.x6.nabble.com/404-not-found-for-http-localhost-8080-geoserver-web-tp5191023p5191045.html
