Please, do use the users mailing list, don't send me private mails.
The mailing list gives you a higher chance of finding someone that
knows how to address your issues, and makes my answers searchable
by other people too.
taixingjason ha scritto:
I try to use Geoserver1.4.0. These are some exception like :
SEVERE: SQL Exception reading geometry column
org.geotools.data.DataSourceException: SQL Exception reading geometry column
Caused by: java.sql.SQLException: Logical handle no longer valid
at oracle.sql.StructDescriptor.toOracleArray(StructDescriptor.java:494)
at oracle.sql.STRUCT.getOracleAttributes(STRUCT.java:411)
at org.geotools.data.oracle.sdo.GeometryConverter.asGeometry(GeometryConverter.java:99)
Yes, someone reported this issue already, but I have no idea on
how to reproduce it. Does this happen always, only when the
server is under load?
