[Geoserver-users] Accessing data in remote drive with user and pass
I’'ve read your post where you said:
“There is one little glitch though, which has nothing to do with geoserver. If you are using let’s say Tomcat as a service at startup and the server with the remote data_dir requires a login you cannot do that as services cannot login to remote servers, you would need to start it via a batch file after connecting.
If it is on your box and you connect to the remote server first and separately, then you can start either batch file or service.”
I’ve a similar problem. I’ve to create in Geoserver a new data Storage that is in a remote device with user and pass.
How can I set the user/pass in Geoserver of this remote Data Store?
Thanks in advance and sorry for the inconveniences.
