[Geoserver-users] Accessing Geoserver from outside
hey
i have been trying to configure geoserver to work in a small network. But i cant access it with ip/geoserver. I referred to the former post at
http://www.nabble.com/geoserver-access-problem-td22645522.html#a22660505
put still cant get through it. I’m using geoserver 1.7.1 . I have stopped my firewall but still errors come out of no where .Can any one give me a
guideline.
The following error was encountered while trying to retrieve the URL: http://10.8.55.39:8080/geoserver/welcome.do
Connection to 10.8.55.39 failed.
The system returned: (110) Connection timed out
The remote host or network may be down. Please try the request again.
Your cache administrator is webmaster.
thankx
deneth
deneth karunarathne ha scritto:
hey
put still cant get through it. I'm using geoserver 1.7.1 . I have stopped my firewall but still errors come out of no where .Can any one give me a
guideline.
    *Connection to 10.8.55.39 failed.*
The 10.0.0.0 network is a local area only one. If you want to access
GeoServer from outside you need to setup your router to perform a NAT
from your public ip address (which you will have to determine)
to your internal machine.
How that is done varies from router to router, there is no single
recipe
Andrea Aime
OpenGeo - http://opengeo.org
