[Geoserver-users] Add a style to geoserver passing the url to an SLD in the request url
Hi list,
I've had a hunt around for a way to add styles to the geoserver config
via a url (or similar).
Basically we've just about finished our tool that lets us create SLDs
using a web interface. These are saved to temporary files so that the
user can view a live example of what their style for a symbol looks
like, as they build it up, using getLegendGraphic requests.
What I would like to do next is upload that style to geoserver, and
apply it as the default style for a specific layer.
I did come across the ingestion engine proposal at
http://docs.codehaus.org/display/GEOS/Ingestion+Engine - it looks like
what I'm talking about.
Has there been any progress with it, or perhaps there is another method
I have not thought of?
Thanks in advance,
Miles Jordan
Applications Developer
The Australian Antarctic Data Centre
___________________________________________________________________________
    Australian Antarctic Division - Commonwealth of Australia
IMPORTANT: This transmission is intended for the addressee only. If you are not the
intended recipient, you are notified that use or dissemination of this communication is
strictly prohibited by Commonwealth law. If you have received this transmission in error,
please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
DELETE the message.
        Visit our web site at http://www.aad.gov.au/
Unforunately there's not been much progress on the Ingestion Engine,
though we would very much like to see it or something similar in place.
For what you're wanting to do it sounds like it just begs an
implementation of PutStyle/GetStyle. That feature is definitely in our
task tracker: http://jira.codehaus.org/browse/GEOS-245. It would
involve re-architecting how we handle styles internally, but would be a
very nice improvement that many would appreciate. Volunteers welcome,
of course :wink:
A quick hack that may help you a bit is at:
http://docs.codehaus.org/display/GEOSDOC/Alternative+for+reloading+the+Geoserver+catalog
Basically the very hacky way to do what you want is to modify the xml
files directly on the server. Then you can use the methods here to
kick geoserver to pick up the configs.
best regards,
Chris
Quoting Miles Jordan <Miles.Jordan@anonymised.com>:
Hi list,
config
like
method
Thanks in advance,
Miles Jordan
you are not the
3 6232 3209 and
DELETE the message.
This SF.net email is sponsored by: Splunk Inc. Do you grep through
log files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD
SPLUNK!
http://ads.osdn.com/?ad_idv37&alloc_id865&op=click
Geoserver-users mailing list
Chris Holmes
The Open Planning Project
thoughts at: http://cholmes.wordpress.com
This mail sent through IMP: https://webmail.limegroup.com/
