[Geoserver-users] Add label
I have renerated SLD file from QGIS, using opengeosuite, I want to add label for my layer, for that I addded oragne color highlighed lines by refering the tutorial, I modified the field name ‘tot_popu’. I saved the file, i uploaded as newstyle in geoserver, but not working. It shows red color highlighd error. please help me. i am not a programmer.
</se:PolygonSymbolizer>
</se:Rule>
se:Rule
se:TextSymbolizer
ogc:PropertyNametot_popu</ogc:PropertyName>
Arial
11
normal
bold
0.5
0.5
#000000
60
150
</se:TextSymbolizer>
</se:Rule>
</se:FeatureTypeStyle>
You need to use the prefix se: on your new elements in the same way the rest of the document does
Ian
refering the tutorial, I modified the field name 'tot_popu'. I saved the
  </se:Rule>
  <se:Rule>
  <se:TextSymbolizer>
<Label>
<ogc:PropertyName>tot_popu</ogc:PropertyName>
</Label>
<Font>
<CssParameter name="font-family">Arial</CssParameter>
<CssParameter name="font-size">11</CssParameter>
<CssParameter name="font-style">normal</CssParameter>
<CssParameter name="font-weight">bold</CssParameter>
</Font>
<LabelPlacement>
<PointPlacement>
<AnchorPoint>
<AnchorPointX>0.5</AnchorPointX>
<AnchorPointY>0.5</AnchorPointY>
</AnchorPoint>
</PointPlacement>
</LabelPlacement>
<Fill>
<CssParameter name="fill">#000000</CssParameter>
</Fill>
<VendorOption name="autoWrap">60</VendorOption>
<VendorOption name="maxDisplacement">150</VendorOption>
</se:Rule>
     </UserStyle>
   </NamedLayer>
</StyledLayerDescriptor>
  * line 290: cvc-complex-type.2.4.a: Invalid content was found starting
    with element 'Label'. One of '{"http://www.opengis.net/se&quot;:Name,
    "http://www.opengis.net/se&quot;:Description,
    "http://www.opengis.net/se&quot;:BaseSymbolizer,
    "http://www.opengis.net/se&quot;:Geometry,
    "http://www.opengis.net/se&quot;:Label, "http://www.opengis.net/se&quot;:Font,
    "http://www.opengis.net/se&quot;:LabelPlacement,
    "http://www.opengis.net/se&quot;:Halo, "http://www.opengis.net/se&quot;:Fill,
    "http://www.opengis.net/se&quot;:Priority,
    "http://www.opengis.net/se&quot;:VendorOption\}' is expected.
Geoserver-users mailing list
geoserver-users List Signup and Options
The same answer, as the error message says it is expecting se:SvgParameter next.
Ian
On 20/08/15 10:33, Iyappan Lakshmanan wrote:
Dear Sir
                 Thank you very much, i tired, Previously I put, Css,
not working, then i changed into Svg, now it is coming like that.
<SvgParameter name="font-family">Arial</SvgParameter>
<SvgParameter name="font-size">11</SvgParameter>
<SvgParameter name="font-style">normal</SvgParameter>
<SvgParameter name="font-weight">bold</SvgParameter>
  * line 294: cvc-complex-type.2.4.a: Invalid content was found starting
    with element 'SvgParameter'. One of
    '{"http://www.opengis.net/se&quot;:SvgParameter\}' is expected.
  * line 302: cvc-complex-type.2.4.a: Invalid content was found starting
    with element 'AnchorPointX'. One of
    '{"http://www.opengis.net/se&quot;:AnchorPointX\}' is expected.
  * line 308: cvc-complex-type.2.4.a: Invalid content was found starting
    with element 'CssParameter'. One of
    '{"http://www.opengis.net/se&quot;:GraphicFill,
  * line 310: cvc-complex-type.2.4.a: Invalid content was found starting
    with element 'VendorOption'. One of
    '{"http://www.opengis.net/se&quot;:Priority,
On Thu, Aug 20, 2015 at 2:47 PM, Ian Turton <ijturton@anonymised.com
    Ian
        to add
        lines by
        saved the
        shows red
           </se:Rule>
           <se:Rule>
           <se:TextSymbolizer>
        <Label>
        </Label>
        <Font>
        </Font>
        <LabelPlacement>
        <PointPlacement>
        <AnchorPoint>
        </AnchorPoint>
        </PointPlacement>
        </LabelPlacement>
        <Fill>
        </Fill>
        </se:Rule>
              </UserStyle>
            </NamedLayer>
        starting
        <mailto:Geoserver-users@lists.sourceforge.net>
