[Geoserver-users] Add oracle spatial layer
I am trying to add a oracle spatial layer to geoserver. I have installed the
required plugins, and started the geoserver. on submit(datasource ->new): On
creating the oracle datasource with the required fields like,
SID,Username,passwrd etc, I get the error message as "Connection Parameters
are invalid" .
What could be the reason for it, I am using geoserver1.6-beta and
gt2-oracle-spatial-2.4-RC0.jar(tried with gt2-oracle-spatial-2.3.1.jar also)
View this message in context: http://www.nabble.com/Add-oracle-spatial-layer-tp14728171p14728171.html
Hello,
I do the same, but it works fine.
Maybe you can use to give your database user resource role in the oracle.
- Gabriel
View this message in context: http://www.nabble.com/Add-oracle-spatial-layer-tp14728171p14729787.html
Have you tested your oracle frist?
The user must be the schma user!!!
goeserver developer wrote:
the required plugins, and started the geoserver. on submit(datasource
->new): On creating the oracle datasource with the required fields like,
Parameters are invalid" .
also)
View this message in context: http://www.nabble.com/Add-oracle-spatial-layer-tp14728171p14736310.html
gabriel dmon ha scritto:
Hello,
Hum, in fact we had a user report saying the ojdbc14.jar we're
distributing did not work for him:
http://jira.codehaus.org/browse/GEOS-1662
May it be a version mismatch between the jdbc driver and the oracle
version? What if you try the jdbc driver that comes with your oracle
install?
After changing the ojdbc14.jar it is connecting.
Hello,
install?
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Add-oracle-spatial-layer-tp14728171p14749656.html
