maven apache wrote:
Thanks for Justin's reply and sorry for my crossing posting, it won't happen again.
No problem ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
2009/12/22 Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>>
If you could avoid cross posting to both lists that would be
appreciated. As this is a development question it is more suited to
the geoserver-devel list.
That said, we are happy about the contribution. However have you
thought about collaborating with the existing wps effort? David
Robison and Andrea have been putting a lot of effort into the
existing wps module so it is definitely starting to gain momentum.
It is built with teh common ows architecture used by services, and
it integrates nicely with the geotools process api.
Yes, the gs-wps is fine. However we have not only wps but also other swe owses(sps,and sos).
It would be nice to have some more information about your WPS
service. How does it work internally? What is the range of processes
that it includes? etc...
The front controller is to get the request string (for get it maybe "request=wps&version=1.0.0....." and for post it maybe a xml fragment" ) ,then parser the string to identify the request type(getCapabilities or DescirbeProcess),then do the business work, build the response document and return.
Ok, and you don't intend to use the current ows dispatcher?
That said, the easiest way to wire up your servlet is to add a
mapping for it directly in the web.xml file, and it can totally
bypass spring all together. This approach has a number of downsides
in that you won't be able to access any of the geoserver internals
such as the catalog. But it is probably easiest.
yes, this is a easier way to implement my requirement, and I also want to build some pages to manager the service just like the web pages to config the wcs wms and wcs in the gs.
Plugging into the wicket UI is generally easy. It is documented in the developer guide:
http://docs.geoserver.org/2.0.x/en/developer/programming-guide/wicket-pages/index.html
Actually I prefer I can add my service in a plugin way like the other ows in the gs.
Ok, so what I would recommend is the following:
1) modify web.xml to create a mapping for your specific servlet, something like:
<servlet-mapping>
<servlet-name>dispatcher</servlet-name>
<url-pattern>/foobar/*</url-pattern>
</servlet-mapping>
This will map certain urls (everything under foobar) to the spring dispatcher.
2) In your modules applicationContext.xml file create a spring controller that wraps up your servlet. See the javadoc of org.springframework.web.servlet.mvc.ServletWrappingController for details on how to do this.
3) Creating a second mapping that maps urls of the form foobar/** to the controller created in step (2). Look in the applicationContext.xml for wfs,wms,wcs,etc... for example, but it looks like:
<bean id="wfsURLMapping"
class="org.springframework.web.servlet.handler.SimpleUrlHandlerMapping">
<property name="alwaysUseFullPath" value="true"/>
<property name="mappings">
<props>
<prop key="/foobar">servletWrappingBeanFromStep2</prop>
<prop key="/foobar/*">servletWrappingBeanFromStep2</prop>
</props>
</property>
</bean>
This approach will let you tie into spring and access the internals of geoserver, but will also allow you to avoid using the current ows service framework.
Hope that helps.
-Justin
Thanks anyway.
-Justin
maven apache wrote:
Hi:
We have implemented a WPS instance, and now we want to integrate
it to gs to replace the wps under the community module of
geoserver 2.0.0(for easily written, I call it gs-wps).
The problem is that our wps have a different architecture with
the gs-wps. I found the other ows such as wcs wms and wfs all
have some common struts: the kvp-parser, response and so on.
Also they all communicate with spring. And each operation of a
ows will be built as a java object for example the
“org.vfny.geoserver.wms.servlets.DescribeLayer” in the wms and
so on.
However in our wps there is only a WPSServlet acted as a front
controller which receive the httpservletrequest and
httpservletResponse as parameters. No matter which kind of
request is received (getCapabilities or DescribeProcess) , they
are all handled by the front controller
So I do not know how to dispatch the request from the client to
the WPSServlet and do some initialization work.
I have seen the gs sources for a long time ,but I have no idea
because of my unfamiliar with the spring.
I also referred to the hello plugin at
http://geoserver.org/display/GEOSDOC/3+A+Simple+PlugIn
But it seems that it does not work.
I hope someone can give me some further advise.
Sorry to bother you.
This SF.Net email is sponsored by the Verizon Developer Community
Take advantage of Verizon's best-in-class app development support
A streamlined, 14 day to market process makes app distribution
fast and easy
Join now and get one step closer to millions of Verizon customers
http://p.sf.net/sfu/verizon-dev2dev
Geoserver-devel mailing list
<mailto:Geoserver-devel@lists.sourceforge.net>
-- Justin Deoliveira
OpenGeo - http://opengeo.org
A streamlined, 14 day to market process makes app distribution fast and easy
Justin Deoliveira
