[Geoserver-users] Adding CoverageStores programmatically
I have a large number of World Image files to add to my GeoServer instance. Is there a command line bulk loader, or an easy way to do this programmatically (in Java, presumably)?
Thanks!
Greg
| E R G O N O S I S
| Greg Ederer
| Lead Developer
| greg@anonymised.com
| 360.774.6848
Hi Greg,
Unfortunately not. The way people do this sort of thing is to write their own little scripts that generate out the catalog.xml file, as well as the info.xml for all the individual coverages.
Not ideal, I know, but something we are working on. There is work going on currently to build a rest api for this sort of programmatic configuration, but its still pretty alpha at this point.
-Justin
Greg Ederer wrote:
Thanks!
Greg
Justin Deoliveira
Software Engineer, OpenGeo
http://opengeo.org
Hi Justin,
Does GeoServer perform some sort of transformation of the raster data when I add it to the server using the web interface? Or, is it just a question of putting the data files in an accessible directory, and making entries in the XML files? If it's the latter, it should be a piece of cake for me to write a script.
Thanks!
Greg
Justin Deoliveira wrote:
Hi Greg,
-Justin
Greg Ederer wrote:
Thanks!
Greg
| E R G O N O S I S
| Greg Ederer
| Lead Developer
| greg@anonymised.com
| 360.774.6848
There is no transformation per se... but there are things that are inferred from the raster, like its reference system, extend, dimensions, etc... So if you have all that information around then its just a matter of putting the data files in the right place and generating the files.
Although some of the above properties if not located in the file will be autogenerated.... but i am not 100% sure. The coverage experts should know more about that.
-Justin
Greg Ederer wrote:
Hi Justin,
Thanks!
Greg
Hi Greg,
-Justin
Greg Ederer wrote:
Thanks!
Greg
Justin Deoliveira
http://opengeo.org
I'm not a GeoServer developer, but I think I can answer this:
From my observation, GeoServer does nothing to the files themselves. You may even set up your filesystem so that the 'user' executing your servlet container has no write rights to the files in question. If you make the entries in the XML config file, you must reload the catalog to the running webapp, which can be done with simple Web service calls. If I'm not mistaken, you can use /geoserver/admin/login.do and /geoserver/admin/loadFromXML.do. I understand that one of the long-range projects for GeoServer is to recode the config structure in a more sophisticated way:
http://geoserver.org/display/GEOS/Roadmap
(see "New Configuration System")
and more immediately, to provide RESTful access to config:
http://geoserver.org/display/GEOSDOC/RESTful+Configuration+API
You must be sure that your files are in a form that your version of GeoServer can handle. WorldImage is safe because it is one of the base types that GeoServer can handle without extra code.
A. Soroka / Digital Scholarship Services R & D
the University of Virginia Library
On Aug 13, 2008, at 8:31 PM, Greg Ederer wrote:
Hi Justin,
Thanks!
Greg
Hi Greg,
-Justin
Greg Ederer wrote:
Thanks!
Greg
| E R G O N O S I S
| Greg Ederer
| Lead Developer
| greg@anonymised.com
| 360.774.6848
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Hello,
This can be done using Java and HTTP.
http://www.olympianengine.com/tutorials/geoserver/index.html
There used to be a GeoServer tutorial that the above page was based on, but
didn't find it with a cursory 'google'.
Good Luck,
-Sam
gederer wrote:
Thanks!
Greg
| E R G O N O S I S
| Greg Ederer
| Lead Developer
| greg@anonymised.com
| 360.774.6848
challenge
prizes
world
View this message in context: http://www.nabble.com/Adding-CoverageStores-programmatically-tp18973309p19034750.html
Thanks, Sam! I will definitely give this a go.
Greg
SamuelToepke wrote:
| E R G O N O S I S
| Greg Ederer
| Lead Developer
| [greg@anonymised.com](mailto:greg@anonymised.com)
| 360.774.6848
