if I’m not mistaken existing cql\filtering math functions [1] will convert the date to a number automatically.
That say, is not clear to me what you intend to do but you may want to have a look at the following functionalities:
I doubt they will support your case out of the box, but they can be an inspiration for a solution.
Best regards,
Nuno Oliveira
[1] https://docs.geoserver.org/latest/en/user/filter/function_reference.html#math-functions
On Tue, 2020-02-11 at 06:31 -0700, Lucas Cantos wrote:
Hello,
I'm searching for a way to make time based arithmetic, specifically addition
and subtraction, from different time dimensions.
I have a single raster data (NetCDF) with hourly precipitation over 5 days
and would like to make something like a rolling sum over different periods
(3h, 12h, 24h and 5d).
A SDL solution would be preferable, but if anything works, i'd be glad.
I'm sorry if this is already done, but i could not find it so far.
Thank you,
Sent from: [http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html](http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html)
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: [http://www.ianturton.com/talks/foss4g.html#/](http://www.ianturton.com/talks/foss4g.html#/)
- The GeoServer user list posting guidelines: [http://geoserver.org/comm/userlist-guidelines.html](http://geoserver.org/comm/userlist-guidelines.html)
If you want to request a feature or an improvement, also see this: [https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer](https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer)
[Geoserver-users@anonymised.comsts.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Nuno Oliveira
GeoServer Professional Services from the
experts!
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
Con riferimento alla normativa sul trattamento dei dati
personali (Reg. UE 2016/679 - Regolamento generale sulla
protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto,
gli eventuali allegati, etc.) è un dato la cui conoscenza
è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è
tenuta/o a cancellarlo, ogni altra operazione è illecita.
Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to
which it is addressed and may contain information that
is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European
Regulation 2016/679 “GDPR” - copying, dissemination or
use of this e-mail or the information herein by anyone
other than the intended recipient is prohibited. If you
have received this email by mistake, please notify
us immediately by telephone or e-mail.
